Old 10-29-2012, 08:03 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
205 Prostar blower hose replacment with full fuel tank
Anyone attempted to replace their blower hose with a full fuel tank? Working on a '96 prostar 205.
The hose goes in on the bottom as one hose and must split into the two rear vents somewhere behind the tank.
Is this a hard Y adapter?
Can I just attach the new hose to the old hose and pull it through? It is really tight on space on top of the tank.
1996 Prostar 205 LT-1
Old 10-29-2012, 08:10 PM
Footin's Avatar
Footin Footin is offline
Boat: 1994 Prostar 205, previously owned 1991 Barefoot 200, 1987 Prostar 190
Did you take out the floor behind the motor box?
OH-IO!
Old 10-29-2012, 08:41 PM
jakethebt's Avatar
Yes. I can see where the single hose goes up behind the tank. Some where up there it splits into two. It is really tight between the tank and the back of the boat.
Old 10-29-2012, 08:42 PM
Footin's Avatar
Mine did not split into two, just one hose attached by the rear vents
OH-IO!
Old 10-29-2012, 08:57 PM
MCOCD@13 out of 10
Tank comes out easy - 8 screws holding it in. Unless its full of course...then it's a PIA...
Old 10-29-2012, 09:41 PM
jakethebt's Avatar
I assume mine is split. I have one hose going under the fuel tank and two vents with two hoses attached to them. Could one of the vents attached to something else?
Old 10-29-2012, 09:42 PM
jakethebt's Avatar
It is full. I may have to wait until spring, but if I can do it with the fuel tank in place, it is just one more thing I can do now and check off the mental list of things to do.
Old 10-29-2012, 09:54 PM
OHIOPRO205's Avatar
OHIOPRO205 OHIOPRO205 is offline
Boat: 1994 PROSTAR 205
It is not hard at all to move the tank. Full or not.
Old 10-29-2012, 10:26 PM
jakethebt's Avatar
Maybe I will try that...
Stx221's Avatar
Stx221 Stx221 is offline
Boat: 1995 Prostar 190, LT1 w/ Powerslot
If I remember correctly from my 1995 Prostar 190, there is one hose that goes from the blower to one vent and a second hose that goes from the other vent down just below the fuel tank for ventilation purposes while underway with the blower off. I swapped both of mine out with the fuel tank in place.
