Old 10-28-2012, 08:08 PM
Boat: 1987 ProStar 190
Thumbs down Need to adjust timing, but dist is seized to engine block.
Now the my boat is out of the water for winterizing, I thought it would be a good time to convert to electronic ignition. Everything went well enough, but the timing was off after the conversion so I went to spin the distributor (hold down clamp is off) and it is frozen solid.
The distributor body is aluminum and the block is cast iron so I'm sure it's galled together pretty good.
I have tried soaking in PB blaster, ATF+Acetone mix and MMO. I soaked the distributor with "freeze spray" to try to get the aluminum to shrink and break the bond with the block. I've also tried moving with a punch and hammer but I'm being very cautious as I don't want to end up with 1/2 of the distributor in one hand and 1/2 stuck in the blck.
So far nothing is moving.
Any other tricks people know about? Has anyone else experienced this?
Old 10-29-2012, 10:25 AM
Spray starting fluid down the dipstick tube and drop a match to pop the distributor up like seating the bead on a tire???
http://www.youtube.com/watch?v=VRJ4M76Wur8
Seriously, have you tried any gentle lifting motions with a prybar? Good luck with this.
Old 10-29-2012, 10:55 AM
I have not tried lifting the distributor yet; should that be my next move? So far I have only attempted lateral movements.
Old 10-29-2012, 11:03 AM
That is what I would try next, using the same cautious approach that you have been taking. You will need to make sure you don't damage the underside of the distributor housing. Perhaps get a metal plate under it to spread out the force.
Old 10-29-2012, 11:29 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
How long was the distributor in the block before you tried to move it?
Bailey
'02 X-9
Lake Blue Ridge
Old 10-29-2012, 11:32 AM
That's a great question; I bought the boat last year (it's an '87). No way to know for sure.
You might try gently tapping down on it also trying to get some movement. The rubber o-ring might have turned to stone.
Old 10-29-2012, 11:38 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
bump the starter motor while lifting on the distributor...
/spôrk/
Old 10-29-2012, 11:39 AM
The dude in the video can move pretty fast...lol
Old 10-29-2012, 12:54 PM
The slow ones are on different videos.
