Old 10-28-2012, 05:15 PM
davidstan's Avatar
davidstan davidstan is offline
Boat: 2008 X2
Battery question
I have a 2 battery set up with a perko switch to shut off power. Do I need to disconnect the batteries for the 4 months of winter or just turn off the perko?
David
2008 X2 MCX
1999 Maristar 210 (sold)
1996 Bayliner 2050
Old 10-28-2012, 05:40 PM
bturner2's Avatar
bturner2 bturner2 is offline
Don't know about what people do in GA but in MI we typically will take our batteries out and bring them either in a garage or basement. I charge or top off my batteries with a charger about every month. Seems to work as I'm going on year 5 on my Blue Tops. If you don't plan on taking them out I would disconnect them to remove any possibility of a drian which would eventually kill the battery. But that's me and I tend to have MC OCD.
Old 10-28-2012, 06:08 PM
waterlogged882 waterlogged882 is online now
John 3:16-18
Old 10-28-2012, 06:53 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - MCX
Switching off the perko is the same as disconnecting them.
Keeping them warm inside and charged is better for them. However, if they can stay on a battery tender all winter, even if outside, they'll be fine.
That's my
Jeff
Old 10-28-2012, 07:14 PM
davidstan's Avatar
Boat: 2008 X2
It is inside and climatE controlled but wasn't sure if the perko was as good as full disconnect
David
2008 X2 MCX
1996 Bayliner 2050
Old 10-28-2012, 07:25 PM
I would. If there's any parasitic drain, you'll return to batteries that are stone dead and will have lost a good amount of their capacity, which will never return.
Old 10-28-2012, 07:47 PM
jgraham37128
Options
Ok, great question, here's my 4 option I can choose. Which would be the best.
1. Remove both batteries and place in my heated garage. The garage will never get below 50 degrees. Most of the time garage is 60-70 degrees. No battery tender till spring.
2. Remove both batteries and place in my heated garage. The garage will never get below 50 degrees. Most of the time garage is 60-70 degrees. Leave plugged up to my battery tender all winter.
3.Leave hooked up in my boat storage unit with the battery tender all closed up unit with insulated top only. The side walls are not insulated but I'm a middle unit so there are 6+ units both left and right.
4. Disconnect the battery and leave in the boat while in the storage unit with no tender till spring.
Old 10-28-2012, 08:16 PM
JDC's Avatar
JDC JDC is offline
I would pick option 2.
Option 2 seems best (to me), while option 3 would be the easiest.
I'm sure you'll get other opinions.
Jeff
Old 10-29-2012, 06:54 AM
davidstan's Avatar
Boat: 2008 X2
I usually do #4. Thx for the input.
David
2008 X2 MCX
1996 Bayliner 2050
Old 10-29-2012, 11:59 AM
Miss Rita's Avatar
x2
I have to maintain four batteries from different toys over the winter. I keep them in my unheated garage that may rarely get below freezing, connect them in parallel, and hook the whole works up to a single battery tender.
