Go Back   TeamTalk > Classifieds Buy/Sell > For Sale: Parts & Accessories
Old 10-26-2012, 04:35 PM
Dixie Dixie is offline
Boat: none
F/S Wet Sounds speakers / JL Audio HD900/5
Wet Sounds speakers / AMP JL Audio HD900/5 5 Channel Amplifier.
If interested best to call me 309-275-9090 as Im not on this site dailey.
Sold my boat and pulled out my expensive Wetsounds and put back in the original system. I have 2 pair of Pro 8 speakers with mounts BLACK 2 pair white SW-650 & white Wet Sounds SW-10FA. All with the white saltwater series grills.
JL Audio HD900/5 5 Channel Amplifier $595 Research this amp it is a Monster.
white SW-650 (per pair) $195
Also have the the white Wet Sounds SW-10FA with white grill $175
All are Wet Sounds are Saltwater series but never anywhere close to salt water or even rain for that matter. Each cost me over $300 out the door just this past June. AMAZING SOUND!
Pro 8 speakers with mounts BLACK $595 pair
Prices plus just actual shipping from Peoria IL
http://www.wetsounds.com/pages/products/SW-650.html
http://www.wetsounds.com/pages/products/SW-10FA.html
JL
Main Channels @ 4 Ω 100 W RMS x 4
Main Channels @ 3 Ω 75 W RMS x 4
Main Channels @ 2 Ω 75 W RMS x 4
Main Channels @ 1.5 Ω 75 W RMS x 4
Main Channels - Bridged @ 8 Ω 200 W RMS x 2
Main Channels - Bridged @ 4 Ω 150 W RMS x 2
Subwoofer Channel @ 4 Ω 500 W RMS x 1
Subwoofer Channel @ 3 Ω 500 W RMS x 1
Subwoofer Channel @ 2 Ω 500 W RMS x 1
Subwoofer Channel @ 1.5 Ω 500 W RMS x 1
Frequency Response (Main Channels) 12 Hz - 28 kHz (+0, -1dB)
Frequency Response (Subwoofer Channel) 12 Hz - 10 kHz (+0, -1dB)
S/N Ratio, referred to highest rated power (Main Channels) >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
S/N Ratio, referred to 1 W (Main Channels) >88.2 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Damping Factor @ 4 Ω >300 / 50 Hz
Damping Factor @ 2 Ω >150 / 50 Hz
THD+N @ Rated Power (Main Channels) <0.03% @ 4 Ω
THD+N @ Rated Power (Subwoofer Channel) <0.05% @ 5 Ω
Input Voltage Range @ RCA Inputs Switchable from 200 mV - 2 V RMS (Low) to 800 mV - 8 V RMS (High)
Min Copper Power / Ground Wire Gauge Accepts up to 4 AWG wire
Fuse Rating 60 A (AFS, AGU or MaxiFuse™)
Filter Modes: Channels 1 & 2 (front) High-Pass only
Filter Slope (dB/Octave): Channels 1 & 2 (front) 12 dB or 24 dB
Filter Frequency Range: Channels 1 & 2 (front) 50-500 Hz
Filter Modes: Channels 3 & 4 (rear) High-Pass only
Filter Slope (dB/Octave): Channels 3 & 4 (rear) 12 dB or 24 dB
Filter Frequency Range: Channels 3&4 50-500 Hz
Filter Modes: Subwoofer Channel Low-Pass only
Filter Slope (dB/Octave): Subwoofer Channel 12 dB or 24 dB
Filter Frequency Range: Subwoofer Channel 50-500 Hz
Detented, Calibrated Filter Freq. Potentiometers Yes
Filters Defeatable? Yes
Infrasonic Filter: Subwoofer Channel 30 Hz, Defeatable
Remote Level Control Optional (HD-RLC)
Remote Level Modes Sub Ch. only
Channel Input Mode Switch Yes (2/4/6 ch.)
Pass-Through Preamp Output None
Source Channel Selection for PreOuts N/A
specs 650'S
4 ohms
All specifications are for each SW-650
RMS Watts: 100
PEAK Watts: 200
Frequency Response: 40Hz to 20Khz
Sensitivity: 90db at 1watt / 1meter
Mid Bass: 6.5 inch composite cone woofer with rubber surround.
High Frequency: Coaxially mounted Titanium Tweeter *
Size & Weight *
Weight: (pair) 7.8 lbs (pair) (5.53 kg)
Sealed Box: N/A *
Diameter: 6.8 inches w/grill (172.72mm) *
Mounting Depth: 3.1 inches (78.74mm) *
Hole Cut Out: 5.0 inches (127.00mm) *
Note:
Note: All specifications are for each XS-10FA
Impedance: 4 ohms
RMS Watts: 300
PEAK Watts: 600
Frequency Response: 20Hz to 500HZ
Sensitivity: 88 db at 1watt/1 meter
Size & Weight
Box Specifications: Optimized for Infinite Baffle (Free Air) applications or .7 cu ft sealed enclosure.
Weight: 8.1 lbs (3.67mm)
Diameter: 11.02 inches w/grill (279.90mm)
Mounting Depth: 4.72 inches (119.88mm)
Hole Cut Out: 9.45 inches (240.03mm)
Old 11-17-2012, 02:15 PM
Boat: none
pics added
Old 02-17-2013, 01:34 PM
osbornda osbornda is offline
Boat: 2005 X-80
the SW-650s sold?
Thanks,
Darrell
Osbornda@gmail.com
Old 04-22-2013, 11:06 AM
Boat: none
Sorry away for the Winter all for sale now
