Old 10-25-2012, 12:31 PM
bjames's Avatar
bjames bjames is offline
Boat: 2009 X-Star LY6
Removing 1 wheel from tandem for manouvering
Any problem removing 1 set of wheels from the tandem trailer just to easily manouver it into a tight parking garage. The wheels would be put back on once parked for the winter.
The reason for this is I use a John deere riding tractor to snake this into a carport for the winter. Its all paved but requires some fairly tight turns. I figured converting the trailer into a single axle will reduce some resistence. Thoughts?
Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower.
Owned:
2012 X25
2011 X25
2009 Moomba LSV
2009 Moomba Outback V
2008 Monterey FS180
Old 10-25-2012, 12:44 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
You are going to need to test and see if the wheel bottoms out on the fender with just one set of wheels on one axle. My guess is it will, but your mileage may vary.
Old 10-25-2012, 12:58 PM
Also, make sure you take off a wheel from each side. Just sayin'
Seriously, if you are looking for maneuverability, try taking off the rear set first. If you rub, then try taking off the front set.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 10-25-2012, 01:10 PM
FrankSchwab FrankSchwab is online now
Boat: 1998 Maristar 200VRS
Wouldn't that make it fairly difficult to actually move the boat?
Old 10-25-2012, 01:11 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Not sure where the CG is on the trailer, guessing closer to the rear wheels to provide some tongue weight. If the X25 is as nose heavy on the trailer as my X2 (compared to an X15 which has much less tongue weight than the X2), you may want to take off the rear wheels anyway just to lighten the load on the tongue.
If you can't find a good balace, take one front and one rear wheel off??
The torsion axles should support the weight of the boat with only 1 set of wheels on, no problem, and not hang the other axle down too far.
Another option if this don't work out well for you is a short wheel base vehicle with a front hitch, maybe borrow a Jeep? I had a side loader garage at the last house that would have been physically impossible to back the trailer into without the using the front hitch on my old CJ. (Required 2 hookups every time we took the boat out. On the Jeep, out of the garage, on the truck, back on the Jeep, into the garage!)
'06 X2 MCX
Old 10-25-2012, 01:29 PM
Rockman's Avatar
Rockman Rockman is offline
Boat: 1995 Barefoot 200 Yamaha ProV 200, 1994 ProStar 190 LT1 1:1
I ran into the same problem when getting our 190 into the house garage this weekend.
I removed the rear wheels on our tandem and the trailer weight was unstable. Seemed more back heavy than anything so I put the rear tires back on and removed one of the front tires just to see if that would work better but the front axle came down all the way to the floor due to the motor weight.
So I bought 4 skate plates off of amazon and will put these under the tires after we get the boat in the garage. They are rated for 6,000 lbs so they should work pretty good.
Old 10-25-2012, 01:31 PM
maristardd's Avatar
maristardd maristardd is offline
Boat: 1994 Maristar 225 LT1
Could you use a set of these instead?
http://www.amazon.com/Skates-Wheel-D.../dp/B000UAGDTC
I have not used personally, but I know car dealerships use stuff like this all the time to move cars around the showroom.
Old 10-25-2012, 01:35 PM
Rockman's Avatar
Yep,
Those are the ones I just ordered:
4 12" Tire Skates Wheel Car Dolly Ball Bearings Skate Makes Moving A Car Easy (Sold by Wayfair).
$199.99 with free shipping.
Old 10-25-2012, 01:48 PM
Miss Rita's Avatar
Boat: 1989 MasterCraft TriStar, 1991 Ski Pro
Removing a set of wheels from one axle of the trailer will reduce resistance, but if your lawn tractor can get the boat into position without removing wheels it's not worth the trouble.
Old 10-25-2012, 02:14 PM
bjames's Avatar
The tractor moved my old Moomba LSV (tandem trailer) fairly easily. This year it will be a 2009 Xstar that will be moved. Its when trying to pivot the tounge and back up thats tough on the hitch. I may try removing 1 front and 1 rear wheel.
Owned:
2012 X25
2011 X25
2009 Moomba LSV
2008 Monterey FS180
