Old 10-18-2012, 10:23 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
propeller turning in neutral
Pulled my prostar 190 out of the water last weekend for winterization. Noticed that the propeller still turned a bit in neutral whil on the trailer. Is this normal?
Old 10-18-2012, 11:12 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
It's normal, but it is not supposed to do that. The clutch pack develops a glaze as the parts age.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 10-19-2012, 03:33 AM
I noticed new fluid reduces the symptom on my 95 with TBI and 1:1 - was surprised to see that.
Old 10-19-2012, 06:56 AM
Wouter's Avatar
Thanks for your answers. Will try changing the tranny oil and see if it makes a difference. How much rotation should I start worrying about? My prop was rotating about 1 revolution per second...
Old 10-19-2012, 10:29 AM
It's very common - I wouldn't worry about it.
Old 10-19-2012, 12:43 PM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
Agree
I have new synthetic fluid in mine and I have all new clutches, springs, plates, front pump, and seals in my tranny and it spins as the op is describing.
Not a big deal
Change the fluid if it has 100 hrs on it and call it good.
Rollin' Gangsta Style
Old 10-19-2012, 01:33 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
You may want to reconsider the use of synthetic in your transmission. Its generally regarded as a no-no in a wet clutch transmission (like those used in motorcycles). Word is that its too slippery, and causes premature failure. PCM specifically warns against the use of synthetic in their transmissions... conventional dex/merc (or dex iii) is the way to go. Avoid high mileage formulations and all additives.
A "dirty neutral" is a sign of a worn tranny... so while it is not proper behavior, it is not exactly abnormal. You should notice that its worse when the engine (and tranny) are cold. If it ever gets to the point where it pushes the boat noticeably in neutral, consider getting it rebuilt. Of course, you should be aware of the potential safety hazard as well.
Old 10-20-2012, 12:25 AM
ZF/Hurth Tranny's like it cool... here's a tech tip I found. http://www.foleyengines.com/resource...x-step-program
