Tire size
Single axle trailer, 1988 pro-star Tire size now is 205-75-14 with a load rating c I would like to go to a 215-75-15 .
Has anyone ever done this before? I am looking to gain some towing capacity Last edited by memphis23; 10-09-2012 at 04:54 PM. |
cant believe no one has an opinion. Guess I will go with the 857 Kumho and stay on 14"
That tire would be a larger overall diameter on the 15" than the 14" wheel. If you go with a larger diameter tire you need to cut down on the aspect ratio of the tire (the middle number) to keep the same overall diameter.
215 is millimeters wide of the tire. 75 is 75% of the width in sidewall height 15 is the diameter of the wheel. |
The larger size will raise your trailer about 3/4". Maybe that's good, maybe not.
I don't think you'll find a 215 75r15 in a "trailer" tire you will need to goto a 225 75r15, either 15" you choose will be wider and taller than the 205 75r14, besides having to purchase new wheels you might run into clearance issues. Personally I would find a D load in the oem 14" size and call it good.
James 1989 MasterCraft TriStar 190 SE |
I bought some Carlisle's because I didn't want to go through all the hassle and have some clearance issue that caused more damages by going with a much "cooler looking" 15" wheel. And full size tire. Then I was told the Carlisle's I bought were crap and the tread seperates from the tire often. And i'm about to drive my new carlisle's 2000 miles. So maybe I should stay out of this thread.
1 Corinthians Chapter 13 - 11 |
HERE IS SOMETHING THAT IS HELPFUL!!
http://www.miata.net/garage/tirecalc.html PUT YOUR ORIGINAL/STOCK TIRE SIZE IN AND THEN PLUG THE NUMBERS OF THE NEW TIRE TIZE IN AND IT COMPARES THE WIDTH AND HEIGHT DIFFERENCES IN EACH TIRE. PRETTY NEAT LITTLE TOOL!! IT SHOULD ANSWER YOUR QUESTION JAY |
They are close in size but few manufacturers produce an ST215/75R15
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#10
@ O2: Wow that is a very helpful tool Thanks!
