  #101
Old 07-23-2013, 10:01 AM
Originally Posted by MikeyOrange88 View Post
Understood. I was trying to carefully craft the wording to indicate that a higher vacuum (lower pressure) would increase the degree that the secondaries would open (wider opening, allowing more air in. Correct? My wording was probably poor, but I stated twice that they are operated only by vacuum.
Certainly not a carb expert, but I do like to drive the boat fast! I've learned a tremendous amount on TT, and continue to, as I read it almost daily. Thanks for keeping us straight.
Sorry, can't put stickers on the boat. Heck, I've not been able to drill any holes in it yet.
The secondaries are held closed by spring pressure so if the secondary diaphragm fails they will not go to full rich. For the secondaries to open, manifold vacuum must reach roughly 6 inches of vacuum before the secondaries will open (approx. 3/4 throttle). Vacuum at idle will approach 30 inches, and as the throttle blades are opened it will continue to drop to near zero vacuum at wide open throttle.
I haven't been able to add any decals to my boat, but it comes with a bunch from the factory so I think I am OK for now. I can still hit 44 MPH so no complaints.
Old 01-16-2014, 09:14 PM
mxhideout's Avatar
mxhideout mxhideout is offline
Boat: '91 PS190, 351 w/'slot
Bump, looking to replace/upgrade the distributor, as the current one is corroded. What do you guys suggest?
Old 01-16-2014, 10:35 PM
There have been some numbers matching distributors found on eBay for not too much. I would try to find one and put in electronic ignition. I have been very happy with my Pertronix EI and coil.
Old 01-16-2014, 10:44 PM
mxhideout's Avatar
Ok, I did a quick search earlier and found this. http://www.ebay.com/itm/Pertronix-Ig...-/170922256137
I'm not too familiar with marine electronic stuff.
Old 01-17-2014, 01:50 AM
Perhaps I didn't get your previous post. Are you looking to replace the electronic ignition or the whole distributor?
Old 01-17-2014, 04:20 PM
mxhideout's Avatar
Mainly just looking to replace the distributor on the cheap.
Old 03-26-2014, 09:06 PM
Did we miss the after pictures? Did the graphics work out?
Old 06-24-2014, 06:08 PM
mxhideout's Avatar
Nope, sorry I haven't updated anything. Been busy with so many other things that we haven't even taken it out yet. Just had my sisters grad party this past weekend, so now it's time to get stuff done. We cleaned and rebuilt the carb and want to test it out this week, but the ignition nut was cracked and doesn't hold the switch when turning the key. Can I just get the nut, or do I have to buy a whole new switch?
1991 ps 190, mastercraft, prostar 190
