X-30 -- Line-X Rear Compartments No More Stink and Mildew
So here's the completed project...
The costs were $650 for the Line-X color matched to Gray. You can save some money by removing all the glue from the cover panels and by lightly sanding the glue off the fiberglass. I also added some Restraurant flooring to add traction and allow for an air gap between the floor and the vests and wet crap that you throw into the lockers. This project seemed pretty straight forward but ended up being quite a tedious process, I did however spray down all my carpets at the car wash and everything drained out really quick and easy. If you live in the Northern Ca area...I can't say enough about the great customer service at Placerville Line-X. Lisa is the owner there and she is possibly the best owner of a small business you can find. She also took care of the Line-X on my fenders, I'll posts those in a bit... BEFORE: AFTER: Sent from my iPad using Tapatalk Sent from my iPad using Tapatalk |
That looks GREAT! Also like the lighter gray color, makes it easier to see down into the lockers and the rubber matting will be perfect so stuff doesnt slide around and sit in water.
Nice job. I have long wondered why MC doesnt do something like the spray in truck liner bed and removable rubber mats. |
Daddy's X-30 Honey Do List -- Nearly Done
Daddy's (X-30) "Honey Do" list
- Line x compartments - Added Cooks Kitchen Floor sections in compartments - Line X fenders - Line X swim Step - Replaced Brake seals and flush - Upgraded to Bluetooth Clarion Marine M502 deck - Welded joints of all trailer step bracket supports - Welded Trailer Guides U bolt connection - Replaced Jack with Fulton Twin Wheel - Added Fulton Retractable Tie Downs - Replaced Winch with Fulton F2 - Remove Stock ballast manifold and added (2) separate thru hole - Polish and replaced Green Ballasts puppies to Pumps - Replace JL speaker covers - Added Fresh Air Exhaust - Replaced Trailer Cuppler and Slide Mechanism - Replaced Trailer Bunk Carpet - ReboltThrottle Bolter - Added Stainless Steel Cup Holders - Added all new LED's on the trailer Sent from my iPad using Tapatalk Sent from my iPad using Tapatalk |
Daddy's (X-30) "Honey Do" list cont...
That tie-down buckle sure looks like it is going to wear into the gelcoat.
The lineX in the compartments looks nice.
Gone, surfing. |
