Old 10-02-2012, 09:19 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
Winterization of an LT1 - Checklist
Well.. first time winterization of an LT1. I have read tons of posts and modified Eastie's (JimN?) checklist and supply list to be specific to the LT1. I have chosen to drain the block, fill with antifreeze and dry block again as it seems a bit more fool proof for noobies and meets all concerns. I have also re-orderd the checklist a bit so you can go right down the list in order. So... have a look and let me know what you think.
File Type: pdf LT1_WINTERIZATION_SUPPLY_LIST rev 1.pdf (45.6 KB, 216 views)
1996 Prostar 205 LT-1
Old 10-02-2012, 09:32 PM
MCOCD@13 out of 10
Originally Posted by jakethebt View Post
Well.. first time winterization of an LT1. I have read tons of posts and modified Eastie's (JimN?) checklist and supply list to be specific to the LT1. I have chosen antifreeze vs dry block as it seems a bit more fool proof for noobies. I have also re-orderd them a bit so you can go right down the list in order. So... have a look and let me know what you think.
I would recommend VR1 Synthetic 20w50 or Royal Purple HPS 20w50. 1996 I believe still a flat tappet engine.
Old 10-02-2012, 09:34 PM
1redTA's Avatar
1redTA 1redTA is offline
Boat: 1981 MasterCraft Limited 351W slot
the LT1 is a roller engine
1981 MasterCraft
19' Skier 351W PowerSlot Deluxe
Long gone is the Trans AM
Old 10-02-2012, 09:37 PM
jakethebt's Avatar
I had a hard time just finding 20W50. Only brand I could find was valvoline. I was hoping for a choice or two. Maybe Mobil1. This was just this past spring. Maybe this fall I will find a better selection.
Old 10-02-2012, 09:39 PM
1redTA's Avatar
i would run good 10w30 on an LT1 the bearing clearances do not warrant 50W oil
1981 MasterCraft
Old 10-02-2012, 09:47 PM
MCOCD@13 out of 10
Cool - wasn't sure...was looking it up and found flat tapped on '94s - would still run VR1 Synthetic/Royal Purple
Old 10-02-2012, 09:55 PM
jakethebt's Avatar
Everything that I can find say 20w50.
Oil was about the last thing I figured we would be talking about after posting the winterization list... I guess you guys think the tasks, order, etc are ok?
Old 10-02-2012, 10:33 PM
Ben Ben is offline
Boat: '94 PS205 LT1
I don't use antifreeze on mine. Was told its bad for the alum heads. Assuming you are using rv stuff, not real antifreeze which would be un tree huggerish.
Also i think I've been using 15/40 for a while now.
Old 10-02-2012, 11:14 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
X2 on the antifreeze. I've heard the plumbing antifreeze is hard on the aluminum heads. I leave my LT-1 dry.
Old 10-03-2012, 07:30 AM
MCOCD@13 out of 10
order looks good...to me at least...
