No fuel pump / no fuel jauge
Hi, I could use some help understand an issue on my '08 X2, with Indmar 350 mcx:
Sympoms are no fuel pump / no ignition / no fuel jauge; occured once for a day a month ago; didn't do a thing and eveything worked fine next day! Same "no start" issue occured again last week (no fuel pump, no ignition , no fuel jauge). The engine cranks ok, but doesn't start. Checked the basics (security switch on, neutral on, fuel at 1/2 level); hot wired the fuel pump and it runs ok. checked the 20 amps fuses at the engine: all 3 are OK interchange the 3 relays, and same (engine cranks but no fuel pump on) disconnect the boat harness, and tried to hot wire the engine on the alternator: same: no fuel pump, no ignition ) Looks like the engine in security because it sees no fuel. i disconnect the fuel sender unit, but have the same. Any one with a clue at what's going on before I turn the issue to the dealer? |
If the engine cranks but you get no gauges I would suggest relooking at the safety lanyard. Sometimes they look like they are pushing the button but just not far enough. You may try pushing it in with your thumb. Even then, the switch could be bad and you might try bypassing it for testing purposes.
Gone, surfing. |
Make sure the ground wire at the rear of the engine isn't loose/corroded and the cables are clean and tight at the battery posts. This isn't just by looking at them without removing, either. |
ditto what jim said. if you open the rear compartment it's just down below the ski pylon on the front of the engine.
Thks to you; I already by-passed the safety landyard, as well the engine red circuit breaker. Grounds wires have been removed, clean up and tighten up. Got 0,4 ohm impedance between batteries' ground and ECM. that 's good enough?
The fuel pump grounds to the rear of the engine- measure from the pump to the block and see what you have for resistance. Also, make sure you have 12VDC at all of the relays and fuses. |
Have 0.2 ohm from pump grounds to engine and 0.3 from ECM to battery post. and I read 12DC at 3 relays and fuses.
If you don't have |
Hi; no buzz, and no voltage at 85 nor 86, even when I turn key On; 12DC only on tab 30 - constant.
