Power loss in 84 S&S
I was on a couple of weeks ago with an impeller issue which I have now solved. Chunks of impeller were back by the tranny cooler and either blocked water or ground up the impeller. HAve since solved that problem, but now I have an odd power loss. The boat ran very hot for about 2-3 minutes when the impeller first failed before I caught the steam and v high temp guage reading.
After fixing impeller, I get a complete loss of power at 2400rpm (about 20mph). I can hold it at 2400 rpm all day but any increase in throttle above that causes a complete bog down of the motor and it drops to idle and dies. This happens only under load. In neutral it will rev up just fine. It starts immediately on the key turn. I have replaced the fuel filter, points, and plugs to no avail. A mechanic rebuilt the carb as his theory was that old fuel had gummed up things. He checked teh pump and tells me it is fine. (It sat idle for a year with Stabil in the tank) This is starting to get pricey now. Any thoughts would be much appreciated. Cheers |
Sounds like the secondary on the carb is not opening. I would double check the carb, might have melted the diaphram when it overheated...
James 1989 MasterCraft TriStar 190 SE |
It sounds like a lack of fuel to me. Have these holley carbs got a small bronze sieve in the inlet like the car ones did/do? Are you sure fuel pump and filter are ok. Next would be to check the secondaries as mentioned above. Have fun.
The secondaries should not be coming in anywhere near 2400rpm, I highly doubt that has anything to do with the issue being described.
Sounds like youre running out of gas at higher speeds... which would indicate a fuel delivery problem.
PCM 351w, 350hp |
Power Valve blow?
JTR
1983 MasterCraft Stars and Stripes Cream/Red Metal Flake "Powerslot" "The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish." -Charles Chaplin- |
Nope. If the power valve diaphragm ruptures, it goes to full rich and runs fat and blows smoke. If you could get it up to speed it would eventually run fine, but can't get there.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
JTR
