  #181
Old 09-10-2013, 03:14 PM
Worthing skier's Avatar
Worthing skier Worthing skier is offline
Boat: mastercraft prostar 190 1993 & 1996
Wiring
Hello all
A few electrical questions ,
The oil pressure gauge is always showing max pressure, but by disconnecting the sensor wire it drops back ,
Checked the resistance of the sensor 250 ohms at rest and decreases by applying compressed air to 5 ohms, so I would think the sensor is ok , got a good feed and earth at the gauge ,any ideas ?.
I do not have a trigger at the fuel pump relay (green /white wire)
does it switch pos or neg ?
I think this comes direct from the ECU , is the fuel pump relay feed as soon as the ign is on or is only when the ECU sees a crank signal ?
Also have a good feed to the injectors but when cranking the is no neg pulse .
Any help would be greatly received.
thanks
Kevin
Old 09-12-2013, 04:41 PM
Ecu
Well I think the ecu has gone down ,
checked with wiring diagram and have got all the necessary feeds and earths
But I have no trigger from the ecu to fuel pump relay , no switched earth for the injectors when cranking , no 5v feed to tps and no feed to the ISC.
Ign coil is being switched when cranked .
I have a ecu number 16189069 , I have found a used ecu with a number of 16234539 which has come from a v6 Mer-cruiser , can I get this reflashed to work ?
Or have I over looked something ?
thanks
Kevin
Old 09-12-2013, 04:57 PM
Should be delco mefi 2 I believe.
Fuel pump should prime when key switched to on.
Old 09-12-2013, 05:52 PM
Hi Mike
I think mine (16189069) is a MEFI-1 as per www.obd2allinone.com/sc/toplevel.asp?cat=32
I have no feed to the fuel pump relay from the ECU , hence why I think the ECU has failed.
Also have found another ECU (16159919) will this work?
thanks
Old 09-12-2013, 06:31 PM
Mefi 1 should be gray.. Iirc ... Not sure of part numbers...
Old 09-13-2013, 06:29 AM
Hi Mike
Which bit should be grey ?
thanks
Kevin
Old 09-13-2013, 11:18 AM
I looked on your site.. The gray color information came from my clymer manual. But I see on your site they are both MEFI 1 and 2 are black.. I would go with the web site info.
Old 09-18-2013, 11:15 AM
Fuel Pump
Hello all
Still working through the loom issues, now run the fuel pump and it sounds a bit noisy and erratic in its operation , was there a well priced supplier that you can recommend.
thanks
Kevin
Old 09-18-2013, 11:47 AM
rick auto -
rock auto $84
http://www.rockauto.com/catalog/rafr...6-P60987-88113 - let me know if they can't ship to the UK.
If they can't I can help you out.
mike
Old 09-18-2013, 11:53 AM
rick auto -
rock auto $84
mike
Mike, that link doesn't work.
