  #161
Old 07-22-2013, 08:57 AM
Worthing skier's Avatar
Worthing skier Worthing skier is offline
Boat: mastercraft prostar 190 1993 & 1996
Alternator
Hello
I have found this alternator in the UK , looks ok , any advise on this .
thanks
http://www.ebay.co.uk/itm/2009096090...076%26_rdc%3D1
Old 07-22-2013, 09:25 AM
Originally Posted by Worthing skier View Post
Hello
thanks
Looks correct...
Old 07-24-2013, 08:52 AM
Hi Mike
thanks for the advise ,I have ordered it .
rgds
Kevin
Old 07-24-2013, 05:26 PM
Block
Finally got the block back tonight and dropped in .
Just looking at the damper plate, I cannot remember which way it faces
i.e does the side with springs protruding, go towards the flywheel or gearbox side.
many thanks
Kevin
Old 07-25-2013, 03:45 AM
Torque settings
Hi
I need the torque settings for the flywheel to crank bolts , also later on I will need the the head bolt settings , does anyone have this info.
thanks
Kevin
Old 07-25-2013, 07:19 AM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
Found this site with torque specs:
http://www.rapidomarine.com/default....ecs-chevy.aspx
When I did mine, I also put a bit of red locktight on the threads, 60 ft/lbs for the flywheel to crank bolts (hardened bolts) and 35 ft/lbs for damper plate to flywheel.
You want the flat side of the damper plate mounted to the flywheel (springs on transmission side, depending on style of plate)
Old 07-25-2013, 09:31 AM
Looking awesome - can't wait to see this girl running...
Old 07-25-2013, 09:48 AM
There is just something alluring about naked pistons.
Old 07-30-2013, 10:17 AM
Alternator
Thanks guys for the answers ,
I bought the alternator from eBay , but its a non ignition protected type so its going straight back .
Found another supplier , which looks to be ok , my next question is this engine this engine a L/H or R/H rotation .
Many thanks
Kevin
Old 07-31-2013, 08:34 AM
alternator
Hi All
I am still trying to locate an alternator ,
Does anyone know what make the standard item is , ie Delco, prestoilte, Motorola etc
and if the 1 of the attached would fit .
thanks again
Kevin
