  #141
Old 03-04-2013, 05:03 PM
Worthing skier's Avatar
Worthing skier Worthing skier is offline
Boat: mastercraft prostar 190 1993
Originally Posted by Table Rocker View Post
Okay, I went out to the boat and took my ('96) dash apart to see if I could find some answers for you.
On the back of the lanyard switch two purple wires come out and go into a small (pencil sized) loom. This loom goes up to the dash behind the speedometers. One of the purple wires goes down to the ignition switch and the other purple wire takes a 180 degree turn and goes into the large loom that heads for the engine. I looked at the ecm and found a purple wire there. No relays are behind my ignition switch.
It looks like the best way to bypass the lanyard switch would be to take the wire going into the bigger loom and connect it to the ignition switch.
If you have any questions, let me know soon while I still have it apart.
Good luck.
Hello
Many thanks for your help and the info ,
as I thought ,the relays are not a standard fitment ,
I think they were to do with boat previously being run on Gas (or LPG in the USA)
will remove them and re wire the kill switch circuit ..
rgds
Kevin
Old 03-04-2013, 05:18 PM
Table Rocker's Avatar
Table Rocker Table Rocker is online now
Originally Posted by Worthing skier View Post
Hello
rgds
Kevin
Glad to help. Let me know if you need anything else. I still have the panel off.
'96 ProStar 205 SD LT-1
Old 03-19-2013, 05:26 PM
Ski Pole
Had the ski pole polished at a local metal polisher ,
It has come out with a near chrome finish ,
not too sure on its finish as I prefer the mat alloy look, but it has remove lots of marks.
Has anyone ever bought the plastic insert on the top of the pole ?
thanks
Kevin
Old 03-19-2013, 05:28 PM
Snipe's Avatar
Snipe Snipe is offline
Boat: Mastercraft ProStar 190 Vortec MX Plus E.F.I.
Is it hard to get out??
Old 03-19-2013, 06:02 PM
No , it is just a allen bolt in the top of the pole .
Have not tried to undo it yet , will do once the pole is fixed back in the boat .
Old 04-08-2013, 07:11 AM
torque settings
Well its been a few weeks of not a lot going on ,
hope to get the block back very soon ,
Does any of you kind people know the torque settings for the big ends, mains and head bolts .
Many thanks in advance
Kevin
Old 05-09-2013, 11:00 PM
supturb89's Avatar
supturb89 supturb89 is offline
Boat: 1996 Prostar 205
Any updates?
-Aaron
1996 RED Prostar 205
Old 05-10-2013, 12:11 AM
nkorep2 nkorep2 is offline
Boat: 1990 Prostar, 351 Windsor
They should be near 90-120 ft/lbs
Old 05-12-2013, 04:23 PM
Hi there
Thanks for the interest ,
still waiting on getting the block back , it is been done at "Mates Rates" so I have to be patient , should not be too much longer .
Anyway the sun has now come out and its a bit warmer here so I am skiing with the 1993 Prostar at the moment .
Will post as soon as the block is back
rgds
Kevin
