how is he going to use it if he doesnt have a tower?
#12
A little JB Weld and Duct Tape outta do the trick!
(I'm sure that would be covered under warranty of 'materials' from the vendor.) |
#13
Nothing other than my the usual - kids on tubes - wakeboarders. The weld is situated about half way up the top above the ski rack...and the crack is clearly above the weld on the tube and not the weld. I rarely use the tower - heck boat has a little over 100 hours over 5 years....the crack has really spooked me as to what "could of happened"...
#14
I would never tow a tube from a tower. Seen too many failures resulting in driver and passengers getting hurt and cut and major damage to the boat from a tower or top deck failing due to pulling a tube.
#16
Tubes are bad, tubs are really bad
#17
Ouch, mystery solved. I am guessing that is what did it..... You wouldnt think towing a tube would be a lot more stress, but it is. I have heard of so many tower failures from that. Still sucks though. Hopefully you can get it fixed up easy enough!! |
#18
The tower is fixable, will you have problems in the future from it.. its hard to tell... |
#19
does it say not to pull tubes from the tower?!
#20
Does it say not to drive in the wrong lane of traffic? If you read the disclaimer for the towers it says not to pull tubes or a cetain amount of weight but who actually reads that stuff? I did cause I was on the toilet bored.
