Old 06-16-2013, 09:58 PM
helton333's Avatar
helton333 helton333 is offline
2003 205v sending unit
I replaced one on a 1989 MC years ago and didn't have to calibrate. Saw a couple messages about recalibrating- would that apply to this model? Not sure how to do that- I am guessing the issue is the sending unit because the gauge problems started first time after winter layup in a heated garage- had about 3/4 tank of gas. Then gradually started reading more accurate as the day went on- I just know nothing on a boat ever truly gets better on its own so thought I'd go ahead and replace it- is it not just bolt and go? Thanks for any help.
Old 06-16-2013, 10:04 PM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
Normally, there are two screws to adjust...right where those two rusty spots are on the sender. This will allow you to adjust when the gauge shows EMPTY and FULL. I always set mine to lie to me a little on the EMPTY setting, which keeps me from running out of gas.
Old 06-16-2013, 10:19 PM
helton333's Avatar
It appears the factory put some sort of epoxy over those screws- doesn't appear to be rust- ?
Old 06-16-2013, 10:24 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
yes its epoxy.just scratch off. adjust the unit then put some silicone back on the screw heads.did this to mine and worked like a charm
---Animal house
Old 06-17-2013, 02:18 PM
helton333's Avatar
so can someone tell me how to calibrate a new one? I can easily understand you fill the boat up and then calibrate to full. Is that it or do you still have to calibrate empty. If that's the case, how the heck do you know when it's empty unless you run it out of gas. I am sure this is a dumb question)
Old 06-22-2013, 01:29 PM
Boat: 2017 X10
Just run it as low as you're comfortable with, and then set it to EMPTY. Take a few gallons with you in a portable tank if you'd like. That's what I did.
Old 06-22-2013, 04:34 PM
HRC HRC is offline
Boat: 2001 Prostar 205V
I did a google search for Centoid products then called them. I gave them the exact numbers on the unit and they sent me a new pre-calibrated unit in under a week for only $64 plus shipping which was less than $10
