Old 04-25-2013, 11:07 PM
tommydbouy's Avatar
tommydbouy tommydbouy is offline
Boat: 2009 X-15, MCX
Yes, pics would be great. Does the cushion with the hinge open without interfering with the seatback?
Old 04-25-2013, 11:13 PM
jmw jmw is offline
Boat: 2009 214V
Will get pics this weekend, have to look for something else for another tt member also. It opens the same as the larger seat about 80% which is why I will probably install the lift catch later but the cooler can be opened and removed easily.
Old 04-27-2013, 08:27 AM
jmw jmw is offline
Boat: 2009 214V
Here are the pics of the hinges and seat installed.
Old 04-27-2013, 08:32 AM
jmw jmw is offline
Boat: 2009 214V
I know the boat is dirty... Been in the barn all winter and haven't cleaned it for season yet for all you MCOCD folks don't worry.
Old 04-28-2013, 05:56 PM
tommydbouy's Avatar
Thanks jmw. So it looks like the hinge is connected to the vertical surface if the boat. correct?
Old 04-28-2013, 06:09 PM
jmw jmw is offline
Boat: 2009 214V
Yes mounts vertically, it's basically the same dimensions as the MC factory hinges and mounts the same way just considerably cheaper. The only thing I did was cut it in half and drill holes. The lines drawn on the hinge are actually where I laid the MC hinge on it to mark it for drilling.
Old 04-28-2013, 09:04 PM
ZachDaddy's Avatar
I found this on ebay....
Old 04-29-2013, 10:30 AM
jmw jmw is offline
Boat: 2009 214V
I don't think the motor hinge will work for the cooler seat because the screw holes face the wrong direction and you need something that will set flush with the seat back or bottom.
Old 04-29-2013, 10:46 AM
214skier's Avatar
214skier 214skier is offline
Boat: Current: 2014 PROSTAR 214v ~ Former: 2010 X14v | 1997 PS190 w/ LT1
You might consider this step next. Makes a huge difference accessing the cooler and libations.
http://mastercraft.com/teamtalk/show...746#post808746
Old 04-29-2013, 12:45 PM
jmw jmw is offline
Boat: 2009 214V
Yes that is my next step just haven't gotten around to ordering one. Do you know the part #? I was told about $50 from MC from a guy at our lake that also installed one.
