Ignition Switch Wiring
Gentlemen,
Could use some help and advise!! I'm helping a neighbor with his 1988 Tristar (351ci). Replacing the existing ignition (original??) switch with a Sierra 4 position replacement switch. The post designatoins on the new switch are easy to decipher however, the post identifications on the existing one are somewhat confusing. On the new switch we have: S = Soleniod I = Ignition A = Accessory B = Battery On the existing switch (not sure if it's original or not), we have: BAT = assuming Battery (Yellow and Orange wires) CC = ? (Light Red wire) CV = ? (Purple/Red wire) ST = ? (Yellow wire with Red Stripe) The colors on the wires are kind of faded so the descriptions may be a best guess. Electrical is not my strong suit. Can anyone tell me what posts on the old switch correspond with the posts on the new switch?? Thanks!!!
1996 Prostar 205 |
BAT = B
ST = S Not sure on CC & CV. But to figure it out, turn the key to Accessory and measure the voltage on the terminals. The one that corresponds to "A" will have 12V, the one that corresponds to "I" will not. If you then turn it to ON and both should show 12V. OR If the switch is out of the boat, and not connected, check continuity between those terminals and BAT. In accessory position you will have continuity between BAT and only one of the terminals, but in ON position you will have continuity between BAT and both CV & CC. |
I am pretty sure that the purple wire is accessory.
Mine works great and no keys.......
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif |
Wiring Color Codes: From ABYC E-11 Table XIV and Table XV.
Green DC Grounding Conductor Bonding Wires (insulated) Yellow or Black DC Negative Conductor Negative Mains Red DC Positive Positive Mains Yellow/Red Starting Circuit Starting Switch to Solenoid Brown/Yellow Bilge Blowers Fuse or Switch to Blower Dark Gray Navigation Lights Circuit Breakers or Switch To Lights Dark Gray Tachometer Tachometer Gauges and Senders Brown Generator Armature Generator Armature to Regulator Brown Alternator Charge Light Generator Terminal or Alternator Aux Terminal to Regulator Brown Pumps Circuit Breakers or Switch to Pumps Orange Accessory Feed Amp Mtr to Alt or Gen Output & Acc Circuit Breaker & Switches Orange Common Feed Distribution Panels To Accessory Switches Purple Ignition Ignition Switch to Coil & Electrical Instrument Purple Instrument Feed Distribution Panel To Electrical Instruments Purple Main Power Feed Positive Mains (particularly un-fused) Dark Blue Cabin and Instruments Circuit Breakers or Switch to Lights Light Blue Oil Pressure Oil Pressure Gauges & Senders Tan Water Temp Water Temp To Sender To Gauge Pink Fuel Gauge Fuel Gauge Sender to Gauge
Many thanks Gentlemen!
I think I'll be able to square it away with this info!!
1996 Prostar 205 |
