Old 08-12-2012, 08:29 PM
dmax185 dmax185 is offline
Boat: 2002 maristar 210vrs 5.7 L eng
02 maristar 210 vrs ballast
Hello everybody im new to this sight and mastercraft just bought an 02 maristar 210 and am looking to install ballast. Checking into flyhigh sacs. Would appreciate any input on weight distribution and how to setup.Is 1 750 lb bag on each side of engine ,400 lb center locker and 650 lb bow sac to much rear weight
Old 08-15-2012, 11:14 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
Heck no that would be a great setup for that boat. I mean perfect. You may however find that you get a bit more very on the wake if you only fill that bow sac to 450-500. The 210 doesnt ride quite as bow high as the 205v hull at boarding speeds and tends to have a much more ramps transitions. You will find you may need to ride around 23.5-24.5 mph for that much weight.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 08-16-2012, 02:39 AM
XtwentyNot's Avatar
Boat: None
Not sure how wide your rear lockers are but the only difference between the 750's and 1100's is that the 1100's are four inches wider. If you have the width just get the 1100's for a few more dollars up front. You can always fill them as little or as much as you want. The ibs is great and is actually 725lbs.
Old 08-20-2012, 04:06 PM
Thanks for your input. I think I'm going to try to plumb a system in this winter
Old 08-20-2012, 11:19 PM
XtwentyNot's Avatar
Boat: None
I recently did mine...
Old 08-21-2012, 01:34 PM
Are those pumps mounted under the floor in the center
Old 08-21-2012, 03:19 PM
XtwentyNot's Avatar
Boat: None
Yes, I made a bracket with some c Chanel and leg screwed it to the beams.
Old 08-22-2012, 03:04 PM
swatguy's Avatar
Boat: Nautique
I gotta say that was a great idea. That looks clean. Never crossed my mind
88 2001 Nautique
Old 08-22-2012, 07:53 PM
I really like that idea not sure if i have room my fuel tank is right in front of the engine and up against the center locker. Thanks for the picture once the season is over i will have to pull up my floor and see what i can do. will keep you posted
Old 08-22-2012, 09:24 PM
bnixon's Avatar
bnixon bnixon is offline
Boat: Mastercraft X10 2001 Vortec 350
Originally Posted by XtwentyNot View Post
Attachment 83133
Nice pump layout! What size and location of sacs did you use and what are the results. (wake and fill/empty times...)
Sent from my iPad using Tapatalk HD
