Old 08-02-2012, 04:02 PM
wakescene's Avatar
wakescene wakescene is offline
Boat: 2001 Maristar 210VRS, LTR 330HP, ZeroFlex Tower, KGB Ballast, PerfectPass Wakeboard Pro,
Aftermarket ECM's/ECU's
Anyone have a source for ECM/ECU in the aftermarket.
I have a 2001 LTR 330hp that's got a bad ECU. I can only imagine what the new one would cost from the dealer...
Old 08-02-2012, 04:16 PM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is offline
Boat: 1987 PROSTAR 190
Maybe these would work
http://www.ebay.com/sch/i.html?_nkw=...+ecu&_osacat=0
Old 08-03-2012, 08:47 AM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
Boat: 1996 PS 190 LT-1/Powerslot
Unless I am msitaken...the ECM and or ECUs are prorgrammed for the specfic engine
that are marinized by what ever company. A PCM programmed ECM will not work on a
INDMAR engine
On occasion they can be reflashed and updated. If you where to take you ECm to your
dealer he could check it for you
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 08-03-2012, 09:05 AM
Flatwaterfooter Flatwaterfooter is offline
Boat: 2006 PS 197
Is the ECM unit different than the DEP Unit?
Old 08-03-2012, 09:47 AM
Boat: Boat
I don't know about a dealer, but I believe Indmar charges $1000 + for new ECMs.
Jim is correct, the ECMs are calibrated for each application, but most of the Indmar CAL files are available to dealers. Using the DIACOM software a dealer, or anyone that knows how to use the software can reprogram the MEFI 4 ECUs.
Gone, surfing.
Old 08-03-2012, 09:58 AM
Boat: Boat
Originally Posted by LYNRDSKYNRD View Post
These will not work. They are MEFI 5 ECMs and the OP has either a MEFI3 or MEFI 4 ECM and my money is on a 4.
Gone, surfing.
Old 08-03-2012, 05:57 PM
ranger098 ranger098 is offline
Boat: 2004 mastercraft x2
i had a similar problem where i needed an ECU for my 04 x2 Indmar predator 310 with a MEFI 4. take my advice and just spend the money on a new ECU from the factory. they are very specific to your boat and it will be extremely hard to find the right one used. if you did find one used, it would either have to be for your exact boat or you would have to pay to have the engine manufacturer reprogram the ECU.
i ended up paying almost exactly 1000 for my ECU, but it saved me alot of time and headaches. it sucks, but ECU's are expensive and i just had to accept that. good luck !
Old 08-03-2012, 06:09 PM
wakescene's Avatar
Question
Good info gents, I do appreciate it.
NEW QUESTIONS:
If the ECM were to go bad, would the motor still run? Also, I am under the impression that the gauges are also run off the ECM. Again if the ECM were bad, would the gauges still work (work meaning, turning the key to the ACC setting and having them reset before firing up the motor?).
Thanks again.
Kevin
Old 08-03-2012, 06:26 PM
Boat: Boat
NEW QUESTIONS:
Thanks again.
Kevin
Hey Kevin,
Maybe we'd be able to offer more help if you explained exactly what your boat is doing or not doing.
Gone, surfing.
Old 08-03-2012, 07:05 PM
it depends on what exactly is wrong with your ecu, i would imagine your engine could still run if there is a minor problem with the ECU. i agree with above, we need a better description of whats working and not working. also let us know what kind of engine you have (indmar, PCM etc)
