Old 08-07-2012, 10:40 AM
College Kid's Avatar
College Kid College Kid is offline
Boat: 93 Prostar 190
Prostar 351, stalls in reverse or when going in to gear.
I have read so many threads on tune carbs and adjusting idle, so thanks in advance, but I just can't seem to dial in enough to make this issue go away. Looking for other things to start to try, or maybe I am missing something.
The PO installed a Holley 4160 last winter but was never able to tune it. He installed it do to the fact that he could never get the boat to idle properly. I was able to get it "tuned in" while on land to around 700-900 rpm. But still have issues when on the lake, seems to need quite a bit of gas when first starting out. Once the engine was warmed up it was is fine going into reverse and forward. I shouldn't say warmed up but when you’re running at speed then slow down and need to reverse (i.e. when you’re picking up a skier) it runs fine.
But as soon as you idle or shut off the engine it seems to have the same issue. Or even at low speed it seems to be pretty quick.
I am no mechanic, but I do my own work on my trucks and have a lot of experience boating with outboards and I/0.
What am I missing? What should I check next? What is the best way to set the idle arm? I am thinking that might be my problem but I am not sure how best to adjust it.
Old 08-07-2012, 11:28 AM
SilviaMan's Avatar
SilviaMan SilviaMan is offline
Boat: 1976 Blue and White S&S
We found that our 76 would idle to fast when warm if we adjusted it to idle well cold. So we deal with the warm up time to get her to idle. Normally its only 1 - 2 minutes before she'll idle on her own.
76 S&S
- T.C.
Daily Grind
Old 08-07-2012, 11:42 AM
Ant time there is a running/stalling issue, the ignition system basics need to be addressed first. Spark plugs, distributor cap & rotor, points (if not converted to electronic ignition), timing and spark plug wires. Next would be carb basics. Is your electric choke operating properly? This could be your problem. It should be almost completely closed on a cold start, and open fully within a minute or so. Next is to check for a carb base gasket leak. This will make for a lousy running boat when it's first started up.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 08-07-2012, 04:36 PM
Thanks so much for this check list. Now for the start of my learning process, first off,
How do I tell if the PO did the electronic ignition? What does it look like? Pictures would be very helpful.
Old 08-07-2012, 05:06 PM
double post
Old 08-07-2012, 06:02 PM
Points mechanically open and close (left picture). Middle pic shows E.I. installed in a distributor, and a points distributor on the right.
- Peter
TIRE & WHEEL SALES
Old 08-08-2012, 12:57 PM
Dino Don's Avatar
Dino Don Dino Don is offline
Boat: mastercraft 190 1987 351 Indmar
Also bear in mind there is an adj for the back throtle plate that has to be right. Small screw underneath the base plate that can only be reached with the carb off. Throtle plate has to have just enough gap .o10-.020 so you can balance it off with the frt adj screw. Too close it's messed up and too wide and you can't slow it down from the frt. adj.
Old 08-08-2012, 07:04 PM
Thanks everyone for the help. Bear with me now as I work through this. I am pretty new to working on a carburated engine/engines in general.
I am going to be checking timing shortly as I am trying to track down a timing light. Does anyone know of a walk through "how to" for that? I have searched but not come up with anything specific to my engine, ie where the hash marks are etc.
Also I took off the cap and took a quick picture can someone confirm that there is no electronic ignition on it?
Thanks!
Old 08-09-2012, 12:51 AM
Yup, those are points in there.
- Peter
TIRE & WHEEL SALES
Old 08-09-2012, 10:56 AM
Thanks, guess I'll add electronic ignition to my winer project list.
