  #31
Old 05-26-2013, 07:14 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Several people have asked about instructions for removing the ballast timer module, so here are some pictures I took when I removed the module from my '07 X2. In my boat, the timer module is located under the port rear seat.
Step 1. Remove the timer module. It is secured with phillips head screws.
Step 2. Remove the control cable plug.
Step 3. Disconnect the power cables to the module. Cover them with electrical tape, or disconnect them from the battery.
Step 4. Disconnect the blue and orange pump power cables. Some boats have bullet connectors on these. I have wire nuts because I didn't want to remove the wire all the way back to the pumps. Label the wires so you can reconnect them correctly.
Once reprogrammed with the new firmware, you can adjust the time in 30 second increments. The procedure to do this is:
1. Disconnect power from the timers and wait 10 seconds.
2. Reconnect power
3. Within 10 seconds of powering up, flip the switch from off>> fill >>off 5 times.
4. The red light will blink a sequence that tells you the current run time. For example:
1 blink, pause, 4 blinks = 14 * (30 seconds) = 7 min.
3 blinks, pause, 8 blinks = 38 * (30 seconds) = 19 min.
5. The red light will then blink rapidly. To add time flip the switch to fill then to the center, or to reduce time switch to empty then to center. Each time you move the switch you will change the run time by 30 seconds. For example, to add 3 minutes, flip it to fill then back to center 6 times.
6. Wait until the rapid blinking stops.
7. The ballast timer will now operate normally, but your time has changed.
The time is retained permanently, until you change it again. If you need to change the time again, start over at step 1.
Here is a video demonstrating the programming procedure.
http://youtu.be/XjcAN0QXhY8
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 05-26-2013, 08:41 PM
g-mantrix's Avatar
g-mantrix g-mantrix is offline
Boat: matrix sorrento 2006 315 mrcruiser
Thats great and will be on my winter list now. Pm to me delivery dets info and cost...cheers
Old 06-04-2013, 02:27 PM
XStar08's Avatar
XStar08 XStar08 is offline
Boat: MasterCraft XStar, 08, LY6; MasterCraft ProStar 190, 91, Ford Mustang;
Just sent mine half way around the world. Looking forward receiving them back soon as summer decided to bring some nice weather... ;-)
Thank you Eric for your work!
Old 06-04-2013, 02:28 PM
ttu's Avatar
ttu ttu is offline
having my timers done was probably the best money spent!
thank you for the great work.
Old 06-04-2013, 02:50 PM
tr6coug's Avatar
Originally Posted by XStar08 View Post
Just sent mine half way around the world. Looking forward receiving them back soon as summer decided to bring some nice waether... ;-)
I got them yesterday. I'll finish them today and gt them back to you ASAP.
Old 06-04-2013, 02:51 PM
tr6coug's Avatar
Your welcome. Glad they are working well for you!
Old 06-04-2013, 02:57 PM
XStar08's Avatar
Old 06-06-2013, 09:27 PM
grizzly grizzly is offline
Boat: 09 X35
Well my timers are on the way,so sick of dealing with these FN things I can't believe something so simple MC can screw up so bad! Can't wait to get them back from tr6coug and get the boating season on the way here in WI!
Old 07-24-2013, 10:09 AM
SJ.'s Avatar
SJ. SJ. is offline
Boat: 2008 X2
Mine will be on the way to you tomorrow (7/25). I appreciate you knocking them out for me!!
I'm amazed we aren't able to do simple time adjustments on the control screen. MasterCraft could have certainly thought that through better knowing lots of people bag out their boats and would want to piggy back the existing pumps.
Old 07-28-2013, 01:24 AM
g-mantrix's Avatar
Originally Posted by tr6coug View Post
Reprogrammed timers are going well. I've done a few from Aus already. I'll post some instructions soon.
Ok, just removed the module, now to pack and ship to tr6coug )Name:  ImageUploadedByTapatalk1374989030.262017.jpg
