Old 04-29-2013, 12:21 AM
snork snork is offline
Boat: 07 xstar
does the red light on the end of the switch work after the reprogramming
what about the auto turn off when ballast is empty
Old 04-29-2013, 02:46 AM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Originally Posted by ttu View Post
just a update, finally got the x2 out today and just wanted to give props, (non pun intended) and was able to fill and empty perfect!!!
thank you again for the great job!
Excellent! Glad I could help.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 04-29-2013, 03:14 AM
tr6coug's Avatar
The light still works. There is no empty sensing anymore after reprogramming. When you flip the switch it runs for the programmed time then shuts off.
Also, after many requests for this, I just finished work on an update that allows you to change the run-time. So, after I reprogram them, you will be able to adjust the time yourself. It works similarly to the programming sequence that Jabsco put into the timers.
To change the time, you do the following:
1. disconnect power from the timers and wait 15 seconds.
2. reconnect power
3. within 10 seconds of powering up, flip the switch to fill 5 times
4. The red light will blink a sequence that tells you the run time
5. Then to add time flip the switch to fill then to the center, or to reduce time switch to empty then to center. Each time you move the switch you will change the run time by 30 seconds. For example, to add 3 minutes, flip it to fill then back to center 6 times.
6. Wait 6 seconds after the last switch move and everything works as normal but your time has changed.
7. That time is retained (even through power cycles) until you change it again.
Future reprogramming orders will ship with this feature. If anybody that already had timers programmed for a fixed time wants this update, PM me.
Old 04-29-2013, 07:14 AM
robpout robpout is offline
Boat: 07 X-Star, LY6 400
Wow...can I send you mine over from Oz... I ordered the 20min timers for my 07 x-star, after I added the flyin high kit 6 months ago. Have been able to get only one of the timers to go properly and have basically bypassed them ATM. Will the original 07 timers (think 6/7 mins) be able to programmed to run for at least 15min fill time....
Old 04-29-2013, 01:07 PM
tr6coug's Avatar
Sure, no problem. Send me a PM and I'll let you know how much return shipping will be.
Yes, I can reprogram the original '07 timers with the variable timing program so they will run for as long as you like.
Old 04-29-2013, 01:31 PM
Boat: 07 xstar
I don't want to jack with the 30 sec programming, can you set the default time to start at 30 minutes and then go up from there if I have the need for additional time?
Old 04-29-2013, 01:32 PM
tr6coug's Avatar
yep, no problem.
Old 05-07-2013, 01:27 PM
197 TT's Avatar
197 TT 197 TT is offline
Boat: 2016 X2 and 1985 SS (Sold - 2008 X2, 2003 197 TT, 1993 205)
Just wanted to follow up with feed back, I have an '08 X2 with Fly High Piggy back system and struggled with my timers all last summer - had tr6coug program all three of my timers to 7 mins and it works perfect. Money very well spent.
Old 05-24-2013, 06:28 AM
g-mantrix's Avatar
g-mantrix g-mantrix is offline
Boat: matrix sorrento 2006 315 mrcruiser
Just to see how the reprogrammed timers are going. I have an 07 and am considering getting this done, but i need to ship from Aus to the US, so just wanna make sure. And any pics of the part that needs to be sent for reprogramming, again just wanna make sure...cheers
Old 05-26-2013, 06:28 PM
tr6coug's Avatar
Reprogrammed timers are going well. I've done a few from Aus already. I'll post some instructions soon.
