Lost reverse 94 190 velvet drive 1:1
Hey guys!
Just came back from skiing and lost my reverse while picking up a skier.No clunk or nothing... Removed cable and engaged it manually but no chance. Changed the transmission oil last week and may have overfilled it by 2-3 ounces no more but skied 10 hrs since then with no problems. Any ideas on what i can check before removing it? T.I.A. Andre
Keep skiing!!!
Bump for you, André. Please hold for the smart posters.
Have you checked on how over-full? Was the fluid really aerated? Turkey baster will work to remove some. Make sure you don't get caught by the wife and wash it out well before you put it back in the drawer.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
Lost reverse in my '79 SNS (351W, VD 1:1) a few months ago, continued to use it without reverse and besides having to push boat off trailer there were no issues although I didn't need to dock it or manuver in tight spaces....
Other than freeing up a frozen motor mount to align everything the job was fairly straightforward; labor intensive but not too difficult. Having someone strong to help get old trans out of boat and new one in is helpful since it weighs abt 100 lbs (kid helping me dropped the new trans - luckily on soft ground). If you're going to do it - good time to replace cooler, hoses, trans mounts, shift cable, mounting hardware. I found my VD 1:1 on Ebay for $435 and there are still a handful there for under $500. Shoot me a PM if you have any questions about the job and make sure you have trans set-up properly for the rotation of your motor; I had to pull mine twice since trans was set for RH rotation and my boat is LH; changing rotation is easy. |
You can download a manual from Basic Power Industries. You can put a pressure guage in on the top of the unit to check your pump pressure in reverse. Since foreward works pump should be fine. Pressure should read 150 psi when reverse is engaged. If it does your reverse actuator may be stuck or you may have a valve issue or the clutch disks are worn out. If it does not you may have a serious internal leak from a blown seal. Either way it will need a tear down and rebuild. If you have good wrench skills you can do it yourself with parts from Skidim, Hale Marine or Basic Power. They will also sell you a rebuilt exchange unit. Could also be a chunk of crud found its way into the valve cylinder. That can be taken out and checked in boat. Good Luck
