Old 08-03-2012, 09:03 AM
bcd bcd is offline
Boat: 93 Larson 200 SEI, 2002 X Star, 2012 X-2
Correction to my first statement - completely filling your front ballast will give you a slightly shorter wave with a longer pocket.
Old 08-03-2012, 09:14 AM
ttu's Avatar
ttu ttu is offline
Boat: 2007 X2
Originally Posted by dfmaus View Post
I'd make a smaller platform, just for surfing, or simply remove the existing one. I recall seeing a couple of threads on here about just that.
agree. i am looking to build a extra "surf" teak platform this fall, just trying to find some brackets for a good price.
Old 08-03-2012, 04:15 PM
tmacx2's Avatar
tmacx2 tmacx2 is offline
Originally Posted by Fab View Post
I'm close to your setup with my 08' X2, instead of two separate sacs in the portside storages, I decided to go big and put an enzo sac down there, and guess what, it fits perfect, 1400lbs if i'm right !
Another 400lbs on the port seat and kgb+front sac filled...
Will post some pics...The wakemakers or waterkis setup is cool but those 400lbs are just small for the rear storage you can definitely go way bigger !
Sounds like a great setup. I don't know if there is a difference in the size of the rear compartments between an '08 and '11. Mine has sort of a shelf in it and I can barely close the compartment when the 455 is full. I can't imagine getting anything bigger in there. Would like to see some pics of your setup and wave. Do you have your enzo plumbed in or are you using a tsunami pump?
Old 08-04-2012, 02:19 PM
Fab Fab is offline
Boat: X2 2008 - 350 MCX
Well those X2 sacs (specs are dimensions: 32 x 18 x 20 weight: 455 lbs. / 206 kg) are filling like 50-60% of the space in my 08' X2 so that's why i snagged a enzo sac...Couldn't take pics today but will ASAP
My enzo is plumbed (so was the stock X2 sac) but it's so big I have to fill it with the tsunami at the same time to complete
specs of the enzo sac...body- 30 x 25 x 26 arm- 72 x 25 x 12 weight: 1450 lbs. / 658 kg.
really fits perfect in rear storage and portside seat !
Old 08-04-2012, 02:40 PM
tmacx2's Avatar
So, the compartments are different. That explains it. In mine there also isn't any room for the arm of the enzo sac to come out of the rear compartment. I talked to someone on my lake that has an '09 or '10 X2 who has a custom sac like I was talking about. When I am done playing around with different weight configurations I think I'm going to get the custom sac and plumb it in, but leave an adaptor for a tsunami also. Thanks for the idea.
Old 08-11-2012, 08:45 AM
tmacx2's Avatar
Haven't been able to get pics with all the weight I've been using but this is with right surf tab down. kgb and port tank filled -650#-, X2 sac -455#, 250# surfside, 250# bow. Total 1605. Will post pics of using 2275# when work and weather cooperate.
Old 08-11-2012, 10:36 AM
BrooksfamX2's Avatar
Boat: 2007 MasterCraft X2
I experimented with the wake plate position last weekend and found with my current set up (posted earlier) and 4 adults in the boat, 50% down lengthens the pocket a bit and there is still plenty of push. 100% down the pocket gets a bit longer yet, but you need to work it a little, but still very surfable....
MISS "B" HAVEN
2007 X2, Indmar 350 MCX
OJ 13.7 x 15.5
2006 F150 SCrew Puller
http://www.crowniehq.net
Old 08-11-2012, 10:47 AM
Fab Fab is offline
Damn that's a clean wake...Almost same weight setup but no tabs on my 08' X2,and i'm VERY far from a clean wake like you, what is your speed ?!
Old 08-11-2012, 04:13 PM
tmacx2's Avatar
9.6 mph. In the 2300# range I think I may have to bump it up a bit to keep it that clean. It was also a pretty calm day with very few other boats so that really helps in keeping the wake clean.
Old 08-11-2012, 04:54 PM
Fab Fab is offline
Well, we mostly ride in smooth water and it's not as clean as yours, I can't get such a clear wake right at the beginning of the platform as it cuts in the wake, wake is shorter and washy at the top...really drives me mad sometimes when I try to recover and that damn wake is washing into my feet and slowing me to death !! :-)
