85 S&S Dash Fuses
Hello TT'ers,
I need a HUGE favor. Can someone out there tell me what size fuses they have for their dash fuses? I am worried that the PO but the wrong sizes in and could risk burning something up. Blower Fuse Pump Fuse Auto Fuse Nav Fuse Anchor Fuse Horn fuse Above Ignition fuse (not sure what this fuse is for until I get under the dash.) THANK YOU!!! |
I e-mailed Discount Inboard Marine (skidim.com) a couple of years ago when I needed to replace the fuses on my '86. Also, let them know which engine you have. They responded very quickly with their part numbers and sizes. They were a direct replacement and could not have been easier to install.
-BDF2 1986 MasterCraft, PCM 351 |
I think 20 Amp
1985 Skier 351 PCM 1.52 Transmission |
I don't have my boat nearby, but I think I went with 10s across the board. Boats been in the water multiple times since then with no problems.
Thanks, I pulled a 30 amp out of the horn fuse. That seemed a little high
#7
I would think ten amp fuses would be sufficient..thirty is a little much..Just my 2 cent
#8
A quick look on Overtons site showed their electric horns rated at 3 amps. 10 amp fuse would be more than sufficient.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#9
I can check tonight, but 30 sounds a might high. I'll try to give them a look when I get home.
I spent most of my money on booze, broads and boats. The rest I wasted. - Elmore Leonard |
#10
Found a 25 in the NAV a 15 in the ANCHOR. The rest are 20's. Seems odd, but I have strong faith in the previous owner. I will check my manual tonight looking for confirmation.
| Tags |
| s&s fuses |
