Old 07-18-2012, 11:24 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
How to wire new head unit
Finally bought a new head unit for my boat: Kenwood KMR-700U. The old Clarion that came with the boat hasn't worked since I bought the boat. I'm very happy with the unit but, just curious how you guys wire the power to the head unit. There are 2 "power" connections, one that connects to the battery to hold presets and clock settings, and the other that is supposed to connect to the ignition so that the head unit shuts off with the ignition. I find this annoying when skiing or riding because the engine is constantly being shut off and restarted when changing riders, etc and the tunes stop. I'm thinking of connecting directly to the battery. What do all you audiofiles do? The only downside I can think of is when my 19 year old son forgets to shut it off and drains the battery.
Old 07-18-2012, 11:46 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
You can wire it its own accessory switch....... this way it can give the constant power with the key off.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 07-19-2012, 07:52 AM
ricford's Avatar
I thought of that, but it doesn't really gain anything. You still have to remember to shut it off when you're done. I was just wondering if anyone else wires it that way.
Old 07-19-2012, 08:22 AM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
I just did a search on some auto shutdown relays and came across this site:
http://www.curioustech.net/timers.html
You might email greg and tell him you want a timer to cut power at whatever number hours you think would be appropriate. I would think a 4-5 hour timer on that relay wouldn't interrupt your listening time unless you're coved out with the radio on for a long time. It also wouldn't kill the battery in 4 hours just running a head unit in the event that you forget to turn it off. Also make sure you mention your application, as it looks like the highest power output is 6amps, and that won't be enough for a head unit. You'll probably want 10-15amp power output (if they can make that happen).
Do you run any amplifiers, or does the head unit power all of your speakers in the boat?
Looks like it could be a pretty useful solution if they can customize that to your needs.
Old 07-19-2012, 08:28 AM
mzimme's Avatar
Actually thinking about a relay more, you could just wire the head unit up per the instructions (to shut off when the key shuts off), but wire a timer into that circuit, so the radio stays on for an additonal 20-25 minutes before the timer relay shuts it off. You'd be able to turn your key off, and have the radio stay on while you switch riders.
That's probably the best way to wire something like that up.
Old 07-19-2012, 09:42 AM
ricford's Avatar
Excellent idea! You'd think, being an electrician I might have thought of that myself. I will investigate 12V timer relays. Thanks.
Old 07-19-2012, 09:49 AM
ricford's Avatar
In answer to your first question, yes I am running an amp and a powered subwoofer, but they are controlled by the blue wire from the head unit, so if I shut down the head unit they shut off as well. I think the timer relay is the way to go. If I'm lucky I might even be able to find one laying around at work.
Old 07-19-2012, 12:50 PM
mzimme's Avatar
Another idea would be to get a new ignition switch that has Off-acc-on toggles, rather than just off/on.
Old 07-19-2012, 09:49 PM
ricford's Avatar
It has an acc position, but it shuts off in between no matter how fast you turn the key, and then it takes about 15 seconds to reconnect to the ipod or memory stick.
Old 07-10-2013, 04:15 PM
charrison327's Avatar
charrison327 charrison327 is offline
Boat: 1996 ProStar 190 LT1
it's great to find old thread with suggestions. i installed a new head unit today and wired to an acc that was not being used per swatguys recommendation..... i was tired of it not keeping memory also. when i turned it off for people to ski or board, i would turn it real fast. there was a slight pause, but it would keep memory. however, if i turned it off for a while i would have to reset everything. works like a charm now
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf - George Orwell
1*
