My 1995 Pro 205 is "missing" at 1500 - 2000 rpm. It isn't skipping it's more of an intermittent miss. I checked the spark plugs and they are all "missing" so it isn't a bad plug or wire. Anyone have experience or an idea.
What engine do you have? Knowing that will produce some recommendations.
James 1989 MasterCraft TriStar 190 SE |
Fuel Filter
Screen on bottom of fuel pump (if it is an electric pump) Coil Wire Cap Rotor Pickup on bottom of tank Muffler Bearings Add Sea Foam to tank Tighten up your Throttle Return Line with a new hose clamp (17/32") unless it's TBW then use a 1/32" torqued to 1.2in-lbs
I live in my own little world. But it's OK - They know me here MONKEY FACE ![]() |
Indmar 350
The engine is an Indmar 350. When it is "missing" at low speed I can hit the throttle and it runs great between 30 - 40 mph. When I slow down the missing starts again.
I'm with Pram. Gotta be the muffler bearings.
#7
I'm not familiar with the muffler bearings. Would you please explain?
#8
Muffler Bearings, or could be the Fetzer valve.
"...gonna' need some pliers, and a set of 30 weight ball bearings (it's all ball bearing nowadays) And I'm gonna' need about 10 quarts of antifreeze, preferably Prestone. No, make that Quaker State..."
1991 ProStar / 351W with 1:1 Velvet Drive |
#9
hey lol... Fetzer valve? lol...this out of hand...
ok...rectifier tube...could be bad...ok seriously...I would add coil to Pram's list... have your ECM read to see what codes are stored besides a misfire...
Additional information! This morning Iwas pulling my grandson wake boarding at 19 MPH. It ran great for about 1 1/2 mile, then started "missing" badly. It seems something is heating up and breaking down electrically. Any thoughts?
