Old 08-26-2005, 02:51 PM
BigBarney's Avatar
BigBarney BigBarney is offline
Boat: '03 X-30, LQ9
Prop question
I sent my prop/boat information to ACME and they recommended replacing my 14" 20 pitch stainless prop with their 13.5" 19.5 pitch prop. Couple of questions:
1. I researched and found out what CNC machined means. But what does nibral stand for?
2. I asked for a prop to give me a stronger holeshot and better speed control. My little pea brain tells me that a larger prop/pitch would move the boat forward quicker than a smaller prop/pitch. Even if the difference is .5 inches. How does their recommendation do this (given it is smaller in size/pitch).
Sorry for probably a redundant question, but I'm still learning about props.
I wuv U, U wuv me - we're a MasterCraft famawee!
Old 08-26-2005, 03:02 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Nibral = Nickle Bronze Aluminum
Less pitch, in my experience = more hole shot. Ordinarily, that also means a bit less top end. But with a CNC'd prop, you can maintain top end with a small drop in pitch.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 08-26-2005, 03:09 PM
gregg gregg is offline
Boat: 2002 Maristar 210 W/Zeroflex Tower
Someone correct me if I am wrong, but I believe nibral in an alloy containing nickel and brass. As brass in a fairly soft metal, the nickel makes it stronger. As far as pitch. smaller pitch is like a lower gear ratio in a differential. More rpm for the same speed. Lower pitch should result in better holeshot, but slightly lower top end.
Old 08-26-2005, 03:27 PM
BRAZOS 205 BRAZOS 205 is offline
Boat: 1997 Prostar 205 - LT1
Nibral stands for Ni Br Al, the three main elements in Nibral. Nickel Bronze Aluminum. Brass is an alloy of copper and zinc.
"Filling my potential would really cut into my sitting around time!" - Bamford
Old 08-26-2005, 03:57 PM
Well, crap. So much for feeling smart today. I would like partial credit. I don't want to have to make this up in winter school.
FAQ
Be kind. Have fun.
Old 08-26-2005, 04:42 PM
You had it right about the Nibral, I just expanded on the brass portion. I'm only a few years out of college and I took a couple Material Science classes, at least I used that information for something.
Old 08-26-2005, 04:46 PM
I give you an A for Affort.
Old 08-26-2005, 05:02 PM
I'll take what I can. I'm trying to be okay with the fact that I know I've spelled it Nibril about 1,000 times in the past.
FAQ
Be kind. Have fun.
Old 08-26-2005, 06:50 PM
canada air canada air is offline
Boat: 1995 maristar 200vrs, 275tbi
acme
do you weight your boat with tons of weight or plan to. it was recommended i go with an 14X18 on my old 95 maristar and i dropped to a 14X16 and sure am glad i did. holds speed awesome and it does not limit you when you get 8 people in your boat you can keep ballast full and still hold speed and still have good holeshot. i did notice you have the lQ9 engine but maybe you should ask them again to make sure a 14X18 would not be better route. again i am no expert. when i send mine into get repaired i may actually get them to prop down to 14X15 but i like to ride with 2500lbs
