Help
Got a SKYLON 2 peice pole on ebay, came today it has a hole with pin in bottom part that goes on my pylon. do i have to drill a hole through the OEM pylon so the pole will not turn? THANKS
No, you set the larger diameter pylon piece over the oem ski pole. Then you put the smaller diameter skylon piece inside the larger one. The pin can be pulled to drop the height of the smaller diameter piece down about a foot or so if you wish to.
If it's a penny for your thoughts & you give me your two cents, what happens to the other penny? Taxes, the democrats tax everything!! 1990 Maristar 210... Sold ![]() In the market though... |
It Doesnt Spin When You Set The Cable Strap Out Front Over The Bow And Get It Tight
Thanks Guys, Skylon pole is up an working good! The cable was to long so had to fix that 3.18$ was a cheap fix, also put one wrap of bubble packing around my pylon an it"s goin tight. Thanks
Thanks mgorczakl1, I"ll check it out they wanted 130.00$ for a 84" cable that works on MC boats. Did it myself for 3.18$
