Old 07-08-2012, 02:44 PM
wely324 wely324 is offline
Boat: 06 X2 MCX, 08 XSTAR LY6
2006 X2 ballast help
Haven't been on here in a while but need some help with my ballast for my 2006 x2. I just put in the boat this week and only my KGB ballast pump is working, the port and starboard ballast pumps are not working.
I checked the breakers, the port seemed to be popped but even pushing it back in, nothing changed. I also checked the impeller on the starboard side to see if there was any impeller damage. none.
I'm going to check later to see if all the pumps are getting power. Just seems odd that the kgb works and not the others unless both motors on the rear pumps went bad.
any help is appreciated. thanks, billy.
Old 07-08-2012, 04:01 PM
sand2snow22's Avatar
Boat: Ri257
What color impeller? Make sure you have green impellers. Do you hear the pumps come on? Use a test light to make sure there is power to the pumps.
Old 07-08-2012, 04:04 PM
mastercraft210's Avatar
mastercraft210 mastercraft210 is offline
Boat: mx x star 01
try opening the pumps and remove the impeller.Then try if the pump roates.If not try to adjust the pin with a small wrench or other tool if you can lose it.Also spray a lot of oil inside to get the bearing creased again.Often after a long period of not using the water will drain true the seal in the bearing and then it will not rotate.
Otherwise there is a problem with the relays but that is not often with both pumps.
Old 07-13-2012, 01:26 PM
c640947's Avatar
c640947 c640947 is offline
Boat: temporarily boatless
Yeah I think relays were bad on mine. They are coming in the mail this week so I know know soon.
http://www.mastercraft.com/teamtalk/...ad.php?t=48636
Current:
Previous Boats:
2006 Mastercraft X2
1995 Mastercraft ProStar 190, New Dimension Tower
1990 Supra Conbrio
http://www.tigerboatdocks.com
Old 07-13-2012, 01:37 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
Open the circut breaker box and look for loose ground. I had a ground come loose causing loss of starboard pump.
2006 Maristar 200VRS MCX
KGB Ballast and all the works! (Once upon a time)
Tow Veh: 2010 Toyota Tundra
Bike: 2009 HD Street Glide
Beer:Ballast Point IPA's
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 07-13-2012, 02:51 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
+1 on that. I had mine apart a few weeks ago and all of the connections were loose. Add some star washers or lock washers to the connections.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
