greased lighting....
Historically I used the blue marine stuff for Boat trailers and Lucas for the racecar trailers. I agree with the PROPER procedure noted above but I just re-pack em with grease pushing the old stuff out unless I am changing compounds/brands/etc - Lazy? I guess but it has worked for racecars and trailers for 15-20 years....(KNOCK ON WOOD) BUT I should note your mileage may vary and/or I replace bearings at the first sign of necessity when doing routine maint, and I dont condone what I do; AND if in doubt go with Timken; they have never done me wrong... Best of luck cj |
#12
Thanks for the info. Going to give it a go tonight. Will post results.
The Wook Burger - 2 patties, 2 cheese, 1 bun. |
#13
Found that out the hard way in high school.. I got a scar almost all the around my pinky finger to show for it... and I have to buy a new bearing. |
#14
An open cage roller bearing is dangerous where it's now a roll of bullets ready to escape. |
#15
Just to add another twist......I have used the EZ squeeze bearing packer for years (30+) and it is the best $20 you can spend if you work on wheel bearings.
http://atoztool.com/270.html Makes quick, clean work of packing bearings. Don't expect to just push down on it with your hand however, you usually have to stand on it because the grease is so thick. Also, on my Loadrite trailer from a few years back it came with bearings made in China. All of those bearing showed excess wear and pitting after the first year of use. I'll stick with Timkens.
I was njskier on here. |
#16
Vs a wad of grease in the palm, forcing little by little into the bearing. |
#17
Mission complete. Hardest part was finding the correct seal. I did not reattach the trailer breaks. Did not have time and just don’t need them. Also put on some new tires. The job was not that bad really. 1st hub took about 3 times as long as the 2nd one just from the learning curve. Bearings looked great and they did not need repacking but it was more for the POM.
Thanks for the help with the comments.
#18
How did you address not installing the brakes? If you left the shoes off then the first time you try to stop the surge brake acuator will push the brake fluid into the wheel cylinder and then push the piston out causing all the brake fluid to leak out. Then the acuator will have a bunch of slop in it.
99 MariStar 230 Sport LTR 330 |
#19
After my wheel bearing repacking, I just put about 900 miles on the trailer this past week/weekend and all was well and functioned flawlessly.
I need to bleed the brake lines in a serious way with fresh fluid now though! |
#20
It rides the exact same as when the breaks were attached. After a stop it slams back when I go, I hate it. I am going to put a bult through it to "lock" it in place.
