Old 06-18-2012, 03:33 PM
JaredOSU JaredOSU is offline
Boat: Mastercraft Prostar 190 351 Windsor 1:1 Borg Warner
PowerSlot transmission
I have a 1989 Prostar 190 with a 351 Windsor and a 1:1 transmission. Would it be possible to change out the 1:1 trans with a powerslot transmission? I am guessing that there might be a different size drive shaft, and with that a different strut. But, will I run into problems under the engine cover or the back hull of the boat?
Old 06-18-2012, 03:39 PM
mzimme's Avatar
mzimme mzimme is online now
Boat: '83 S&S w/ PowerSlot
Shaft size is different. Not sure when the hull began being a standard design, but I know in 83 with my slot tranny it has a bubble molded into the hull to fit the bigger prop.
Old 06-18-2012, 03:49 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Yes, you can. But you will have to replace not only the transmission , but also the shaft, strut, and prop.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 06-18-2012, 07:22 PM
pictures
Could you guys check these pictures to see if the hull in the back will accept a larger prop for a powerslot trans?
Thanks
Old 06-18-2012, 09:59 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Like east tx said, you'll have to replace shaft, strut and prop. Rudder should be okay. Why do you want to do this? Can't believe you don't have enough hole shot with your setup.
Old 06-18-2012, 11:10 PM
MC Hero
At that point, the hulls were the same whether there was a 1:1 or a 1.52:1. Larger wheel should fit.
FAQ
Tyler Ski Club
Old 06-19-2012, 05:04 PM
ricford's Avatar
I don't think you will see a huge benefit to the power slot for the cost involved. You'll probably get better performance for a lot less money by re-propping.
