Old 06-15-2012, 12:07 PM
sheckski's Avatar
sheckski sheckski is offline
Boat: 2000 205v ltr
ballast switches
I picked up a pair of switches from wakemakers and note there are 6 leads but ultimately only two go in and 2 should come out. Anyone know why 6 leads and - if so - how to wire? On a related note i have eliminated my hydrolic hatch ( 2000 205v ) and am thinking that wiring harness ( which ends in two leads ) can probably be used as well. Has this been tried?
Old 06-15-2012, 12:35 PM
JRW160's Avatar
JRW160 JRW160 is online now
Boat: 2003 X2
I'm pretty sure mine are hooked up like this.
Old 06-15-2012, 12:38 PM
JRW160's Avatar
Boat: 2003 X2
Maybe it will work this time
Old 06-15-2012, 12:39 PM
sheckski's Avatar
Boat: 2000 205v ltr
meaning how? Do you know what the wiring plan is?
Thanks
Old 06-15-2012, 12:43 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
Do you have the aerators or the reversables? They each have a different configuration. I know aerators were the standard back then just not sire of you upgraded
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 06-15-2012, 12:47 PM
JRW160's Avatar
Boat: 2003 X2
That diagram I posted is for reversible pumps. I assumed you had reversible when you said 2 going in and 2 going out.
Aerator pumps would just be one pump connected to A and D and the other connected to F and C with Vs and ground in the same place.
Old 06-15-2012, 01:12 PM
sheckski's Avatar
Boat: 2000 205v ltr
I am using jabsco reversible puppies. Thanks for that diagram. If i understand correctly I am jumping C and D , A and F .
Thanks again
Old 06-15-2012, 01:45 PM
sheckski's Avatar
Boat: 2000 205v ltr
wiring diagram from wakemakers. I guess it is actually a 7 terminal switch. in any case, for the next guy.....
Old 06-15-2012, 02:12 PM
JRW160's Avatar
Boat: 2003 X2
7 terminal is functionally the same as 6, it just has a light
Old 06-15-2012, 02:28 PM
sheckski's Avatar
Boat: 2000 205v ltr
my plan is to pre jump 5+7 , 1+6, 3+4 and then just wire the remaining once in the boat.
