Old 06-13-2012, 04:03 PM
Hrkdrivr's Avatar
Hrkdrivr Hrkdrivr is offline
Boat: MasterCraft X-45, 2006, L18, slate gray/white
Prop strike, vibration
2006 X-45, L18.
Pulling my daughter around on her wakeboard on Lake Oconee, first day of vacation, BAM, feels like we hit something and then we get a terrible vibration. (there goes the vacation )
We're able to make about 1400 RPM and 8mph before the vibrations get too bad.
Got the boat onto the trailer. No damage to the prop. Spinning it by hand I don't feel any grinding or anything out of the ordinary. Shaft appears to be straight and strut seems undamaged. Running the engine in neutral and revving it up is normal and smooth. I can't find/see any pieces/parts/chunks under the engine. Transmission oil is new, full and has no water intrusion.
I can imagine a water-soaked log being stout enough to cause tramsmission issues but maleable enough not to damage the prop.
Here's the question: Is it possible that hitting a log would transmit enough of a jolt to make the dreaded damper plate give out?
Second question: How the heck do you pull the transmission in this boat? It seems like I can get to all the connections, but I cannot imagine how you get it out of the way with the limited work space, fuel tank in the way, etc.
Thanks in advance, this forum has been a lifesaver!
2006 X-45, L18, slate gray/white
I am leaving it as I found it. Take over. It's yours. - Ellis Wyatt, Atlas Shrugged
Old 06-13-2012, 04:18 PM
NatesGr8's Avatar
NatesGr8 NatesGr8 is offline
Boat: 05 X-45
you have a bent prop, look at it from the side, not straight on from the back. i bet you'll probably notice one blade looks off from the others. It doesn't take much to throw the prop out of whack and cause vibrations. I would also check the shaft at the prop seat for excessive runout. That might be bent too, anything over 0.003" is too high.
Guns don't kill people, I kill people
Old 06-13-2012, 04:19 PM
Trig2275's Avatar
Trig2275 Trig2275 is offline
Boat: 2010 Mastercraft X-15
Lots of stumps in Oconee.
Old 06-13-2012, 04:33 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
^^exactly^^
PCM 351w, 350hp
Old 06-13-2012, 04:51 PM
gusolah's Avatar
gusolah gusolah is offline
Boat: 2012 Mastercraft X7 ilmore 6.0L
Same thing happened to me a few weeks ago. Bent prop..went from a three blade to a four blade and 420 dollars later she is running good.
I am here: http://tapatalk.com/map.php?r2ek5o
Old 06-13-2012, 08:27 PM
Chrisoswald Chrisoswald is offline
Boat: 88 Prostar 190 & 2006 Chaparral Sunesta 232
I agree bent prop. Especially if the shat spins easily. I just went thru a slightly bent strut and I had to use two hands to spin the prop.
Oconee is basically a forest covered with a little bit of water covering it. Be careful.
Old 06-13-2012, 08:51 PM
ted shred ted shred is offline
Boat: Mastercraft,powerslot,1983,pleasurecraft 351
A prop only needs to be bent very little to cause vibration. Sometimes you can hardly tell even when you look at it.
Old 06-13-2012, 11:06 PM
goebelt goebelt is offline
Boat: 2006 x45
Check the shaft with a dial gauge. Check behind and in front of strut. Fasten it to the trailer so it is fixed position. I used a piece of angle iron clamped to the trailer.
Old 06-13-2012, 11:09 PM
Tom190driver Tom190driver is offline
Boat: Mastercraft prostar 190 1990 351w
you have a bent blade this happened to me on lake west point by a log. you need to pull prop an look @ it from the side, one blade on mine was bent toward the hub. i called Eric @ OJ PROPS had a 13-13 LC Force 4 blade in 1 day sent him the old prop it was trashed he said so i got another backup 13-11.5 imp.90 it only takes 5mins to change props with a good prop puller. Both props are great on my 190 prostar.
Old 06-14-2012, 05:32 PM
Hrkdrivr's Avatar
Just got home and am on the way out to pull the prop. Looking at it on the boat I can maybe BARELY see the trailing edge of one blade may be bent the slightest amount...
I'll post pics if you can see anything on them...
