Originally Posted by j.mccreight@hotmail.com
Since your issue is with the fuel gauge I would concentrate on that. Disconnect leads from sender and disconnect leads from gauge and then measure the resistance of each wire seperatly one to gauge the other to a good ground on engine or battery anything less than .5 ohm is ok, make sure you disconnect battery first. You could also run a new signal wire from the sender to the gauge as a trouble shooting method. Ensure the gauge is getting full battery voltage and ensure the ground on gauge is also good. On a tristar there is a large wire junction about 12 wires iirc, on the rear of engine near the bilge, check that and clean as necessary. fairly simply circuit, sender has a ground and a signal, the gauge has a power, ground and the signal and then the light circuit.
I am determined to fix this so thanks a ton for taking the time to help. I understand what to do however I'm stumped a bit. And I may show some ignorance here but when I touch the two leads at the sending unit together the gauge pegs way past full. I assumed that would also means that the wiring was good but clearly this is not the case. Can you help me understand why?
