Old 06-13-2012, 09:49 AM
Fab Fab is offline
Boat: X2 2008 - 350 MCX
Ballast pump doesn't start...
So, another issue about the ballast pumps :
I went to my '08 X2 today to make some cleaning and noticed the Port en STB pump would not start, KGB works perfect (engine OFF)...
When I hit the switch either in Fill or Drain, I can hear the relay clinking but pump doesn't start AND the LED on the switches is blinking 2 times
I found that these 2 blinks would indicate a clogged/blocked pump or high draw...
I didn't have the ignition key so I couldn't test with engine idling at 1500rpm, Could it be a problem of low battery as my boat is sitting on the water and it rains a lot here so the bilge pumps work a lot I believe which could drain my batteries...
Old 06-13-2012, 09:56 AM
G-Star's Avatar
G-Star G-Star is offline
Boat: 2002 X-Star, LTR
Could be a seized impeller. They can stick pretty solid after not being used for a while.
Pull the cover off the pump head and take a look at the impeller. Throw some glycerin or soap in there as a lubricant, spin it by hand a bit, and see if that helps. If not, try pulling the impeller and running the pump briefly without an impeller installed.
2002 X-Star w/ LTR
Old 06-13-2012, 11:13 AM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
I had the same issue where one of my pumps would not run when I was testing with the engine off. I put the battery on a charger, tried again a couple hours later and the pump ran just fine. I suspect this is why it says to run the boat at 1500 rpms when filling the ballast.
Old 06-13-2012, 11:23 AM
Dan_Lorenze's Avatar
Dan_Lorenze Dan_Lorenze is offline
Boat: Mastercraft 2006 X30
I had the same problem, was a tripped circuit breaker on mine.
2006 X30
Old 06-13-2012, 12:44 PM
Fab Fab is offline
didn't check the impeller as it was working perfect yesterday !! Fuses look OK, The weather is so ****ty I can't test with engine running...
Thx for your inputs !
Old 06-13-2012, 01:01 PM
Georgeohh Georgeohh is offline
Boat: MasterCraft X2, 2009, MCX, Ruby Red Flake
Same thing happened on my 09 x2 last week. Revved it up to 1100Rpms, pump worked just fine.
http://theskimonster.com
2009 MasterCraft X2 MCX Ruby Red Flake
Old 06-13-2012, 02:41 PM
Fab Fab is offline
Those timers are really a PITA, It seems there is a code for low voltage (4 blinks if i'm right), but It looks my batteries may have good voltage but low amp...
Old 06-13-2012, 04:17 PM
bjw444 bjw444 is offline
Boat: nautique and hopefully xstar soon
The pumps have a Bearing in the back case which the whole motor spins on, it's possible that is stuck and just needs broke loose and cleaned up, my friends 2010 x55 had 2 out of the 3 motors do that from sitting, just take the pump off take the 2 bolts that hold the back on and pull the cover off,
Old 06-14-2012, 12:48 PM
mseller mseller is offline
Boat: 2008 X45
i had all 3 of my pumps giving me the 2 blinks. I decided to throw out the timers and do the relay project. all 3 pumps work flawless now.
http://www.mastercraft.com/teamtalk/...t=22234&page=7
Old 06-14-2012, 02:46 PM
Fab, try unplugging the connector that goes to the KGB pump and plug it into the port pump, just to see if the pump works and it's not something else like a short somewhere.
iPhone Tapatalk
2006 X30
