  #61
Old 03-23-2013, 08:34 PM
SSMoose SSMoose is offline
Boat: 1983 Stars and Stripes PowerSlot
I think your boat looks great. I just wish that I could afford all the work. I seem to only be able to screw it up when I try to do the work.
Old 03-23-2013, 10:04 PM
Fantastic work!
Old 03-23-2013, 10:38 PM
BROUSSARD's Avatar
BROUSSARD BROUSSARD is offline
Boat: 2012 MasterCraft Prostar 197
Looks amazing! Redoing the pylon next?
Old 03-27-2013, 10:43 PM
oldschool oldschool is offline
Boat: 1984 Mastercraft Stars and Stripes
Thanks y'all, almost done with her. Took it out last night and had a blowout and the motor kept backfiring out of the flame arrestor? Is that common for engines that have been sitting? Hopefully it's not a valve issue. I hate taking the exhaust manifold off. The pylon will probably remain janky, I've got a fly high pole that goes over it. I still need to put the underwater LEDs on and some new gauges and probably by then it'll be back to motor work lol
Old 03-27-2013, 10:45 PM
LEDs and amp going in
Old 03-27-2013, 11:24 PM
If you backfired through the carb, you have most likely blown your power valve- unless you have done the update. Pull the bowl, remove the power valve and check it out. Then check the routing of your plug wires. If they all go to the correct holes in the proper order, check the timing. Hopefully on of those issues and not a flat cam.
Old 03-28-2013, 12:28 AM
I'm sorry, I haven't the slightest clue what a power valve is. Could you fill me in?
Old 03-28-2013, 09:36 AM
BROUSSARD's Avatar
Can't wait to see the finished project! Just a suggestion: even though you plan to use a fly high I would redo the pylon now while you are working on the boat (will make it easier to sell)
Old 04-03-2013, 09:13 AM
cptskier15's Avatar
cptskier15 cptskier15 is offline
Boat: Stars and Stripes 1980
Project going so well! Must look for an upholster for our S&S. Also want a bimini top this summer!
Old 04-03-2013, 03:56 PM
Threw in the towel on the carb rebuild and just bought a new one.. It was an automotive carb anyways. No more bombs waiting to explode over here lol.
