#31
And I think BlueSea Systems makes a replacement that is virtually bolt in. I did it (and the wiring later) because some prior owner re-soldered the board that the fuses install on but were still questionable.. cj Last edited by ctjahn; 07-19-2012 at 07:43 PM. |
#32
Dont forget to replace the Flux Capacitor. That's key to a healthy engine. :-)
#33
Taking it out for a test drive. We'll see..
#34
Thing was running great for about a week there.. back to the help board :/ . While out on the lake the boat was just floating and when i went to start it, nothing. I got gauge hop and power to the dash but nothing to the block. To remedy this i bridged the two wires that connect to the transmission, and that allows me to turn the engine over but am unable to get any spark. Even after triple checking to make sure the boat is in neutral it still won't turn over without those wires being bridged. I have a new coil, just changed the cap and rotor, and had rewired the engine a few weeks back. I don't think my wiring is at fault due to it functioning previously. Still no spark. Open to any suggestions. Would it be possible the sensor went bad inside the distributor? As always, thanks for the great help.
#35
Safety switch?
Quote: Originally Posted by Hoosier Bob She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
#36
Don't for get the battery cables, no matter how good they look. Proper ground and good spark are the lifeblood of a proper running boat. Ive been there.
"I care not what others think of what I do, but I care very much about what I think of what I do !....That is character"
#37
figured it out.. distributor had teeth missing, had a bad neutral safety switch, and the timing was off due to the teeth missing. ended up changing the wiring, again, new valve covers, new alternator, carpet, pertronix distributor, plugs, wires, and now i get to winterize it.
#38
Nice! I have the same boat. Engine is running great, just looks ****ty. I have a problem with not leaving "Good Enough" alone and having it bite me in the ***. I will clean it up at some point.
Can't wait to see how this turns out. |
#39
Nice work so far!
It always pains me to see something nice get neglected like that. The PO really did not care for that boat at all.
1991 ProStar / 351W with 1:1 Velvet Drive |
#40
James 1989 MasterCraft TriStar 190 SE |
