Old 06-04-2012, 10:47 AM
Masternorth's Avatar
Masternorth Masternorth is offline
Boat: Mastercraft X10 2014
No power to radio on 2008 X2
Hi,
There is no power to my radio. I have changed the fuse that is right at the battery and checked the one below the steering wheel. Where else should I check? The batteries were not correctly connected by the dealer that has winterized my boat and I am worried about more serious damage. Before I go back there, I want to identify the problem if I can. Is there a fuse on the amp?
Thanks
'14 X10 GEN2
Old 06-05-2012, 12:35 AM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
Originally Posted by Masternorth View Post
Hi,
Thanks
The fuse right at the battery is probably for the amp. There should be a fuse on the power wire near the back of the head unit.
2006 Maristar 200 SS
Old 06-05-2012, 02:33 PM
I looked quickly last week-end through the front seat opening and I did not see it but I guess I will have to lie down under it with a good flashlight.
Would you know what type of fuse goes there?
Thanks,
'14 X10 GEN2
Old 06-05-2012, 03:01 PM
rgardjr1's Avatar
Thanks,
I'm pretty sure it's a square blade automotive fuse. I think it will be in a black plastic holder. My boat is an hour away so I can't check for size.
Old 06-06-2012, 10:19 AM
Thanks for the info, my boat is also an hour + away so it will wait for the week-end...
'14 X10 GEN2
Old 06-11-2012, 02:02 AM
cal2vin's Avatar
cal2vin cal2vin is offline
Boat: 2013 Mastercraft x25 6.0 Ilmor gen 1 surf
This happened to mine stereo as well. It was a bad breaker in that panel under the steering wheel. Since I don't have the seat heat option i just moved the stereo wires from its original breaker to the seat heat one and haven't had a problem since. Although now there is constant power to the stereo. The key does not shut it off so you have to remember to turn it off manually when you are done.
Old 06-11-2012, 11:45 AM
It was finally the fuse on the power source to the radio, underneath the glove compartment. It is a 15 amp fuse and I changed it and everything is back to normal.
Thanks for all the tips.
Robert
'14 X10 GEN2
