Old 05-30-2012, 11:58 PM
Nick911's Avatar
Nick911 Nick911 is offline
Ballast Tank Pumps and Engine RPM
Have 2012 X25 with 6.0 Ilmor. Manual says I should be running at at least 1500 rpm before running the ballast tank pumps. Does anyone do this? Is there any harm in being lower? What I've been doing is filling and emptying while we ride around, or, sitting in high idle letting the tanks fill and empty.
Insights?
Old 05-31-2012, 12:06 AM
Trig2275's Avatar
Trig2275 Trig2275 is offline
Boat: 2010 Mastercraft X-15
I always fill stationary with RPM's at 1500 and empty moving forward slowly.
Old 05-31-2012, 12:10 AM
Nick911's Avatar
Any reason why you empty moving ahead slowly?
Old 05-31-2012, 12:18 AM
Trig2275's Avatar
Read it on here in a similar thread. The consensus was to fill stationary but definitely have the RPMs over 1500 and empty in motion. Probably doesn't matter when you're emptying other than saves time getting where you going.
Old 05-31-2012, 03:28 AM
Cobra Rob Cobra Rob is offline
Boat: Mastercraft X-45
We usually fill and empty while going through the no wake zone on the way to our spot.
But if not I usually have it in idle. I don't see any need to rev the engine in neutral I am sure it has to mostly with the current draw from the pumps but we have a bunch of high output batteries for the audio anyway.
Old 05-31-2012, 05:07 AM
Fab Fab is offline
Boat: X2 2008 - 350 MCX
Idling at 1500rpm will supply more power to the pump and thereforeyou will hear the pump running faster...Same goes with fat sac pump plugged on the 12V, will run faster at 1500rpm...
As I have some fat sac plugged on the overflow of the stock ballast, if I don't run a full (4 min) filling cycle at 1500 rpm then the fat sac doesn't fill completely for example...
Old 05-31-2012, 06:40 AM
MattsCraft's Avatar
1500 RPM is to keep the voltage up. The inlet/outlet for the tanks are on the bottom of the boat. Think about it, trying to fill in motion is harder on the pump, likewise for empty, in motion puts less pressure on the pump to allow the water to flow out.
I have more than 300 hrs on my boat, use this method and I am on the original impellers with overflow bags in the rears. Fill standing still 1500 RPM's, drain plowing at 1500 RPM's. Pumps almost never time out
Old 05-31-2012, 07:24 AM
Boat: No Boat
I motor at no wake speed from the launch to riding area.
Tim
