Old 05-07-2012, 02:21 PM
dboat dboat is offline
Boat: 1994 Mastercraft Maristar 225 VRS
how to level the trailer for proper hitch hgt
How do I find the proper level height for the tandem mc trailer for my hitch stinger. I would think a little lower in the back to let the water run out but should I line up the leaf spring brackets to eyeball level? I saw a post on here earlier but can't find it.
Old 05-07-2012, 03:08 PM
MC Platinum
A tandem trailer should sit level with equal weight on each axle. If not, the axle with more weight will prematurely wear out tires. Set-up is to find the correct height for the trailer to sit level and buy the appropriate draw bar. Trailer bunker attitude should allow for the stern to sit a little lower to allow proper drainage.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 05-07-2012, 03:10 PM
Miss Rita's Avatar
The trailer should be level while towing, you shouldn't adjust trailer attitude for drainage, that's something to worry about while it's stored.
Leveling is easy, all it takes is a tape measure and a flat parking lot. The main frame rails of the trailer should be the same height front and back while hooked up to your vehicle. Raise/lower the hitch to make it right.
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
I would put the truck and trailer on level ground and use the trailer jack to level the tongue of the trailer. Then go get the right lift or drop stinger. You want the trailer level while pulling it. I used a level on the tongue of my trailer and got it to were it pulls perfectly level and then measured the trailer and hitch with a tape measure. You DO NOT want to pull it too high or too low. As far as draining the exhaust or whatever you are trying to accomplish by having it at an angle, well that is what hills are for.
Pulling a trailer not level will cause the ride to suffer and the trailer to not pull right.
Rollin' Gangsta Style
Old 05-07-2012, 05:51 PM
petermegan's Avatar
I wouldn't have thought it was not TOO crucial to get it perfectly level. Rocker springs will equalize the load between the two axles.
Old 05-07-2012, 07:46 PM
I must be thinking if the rocker springs, they are unbalanced right now, so I should make them level? Should I be concerned more about the rocker springs or the trailer frame being level? Thanks for your input so far.
Old 05-07-2012, 08:04 PM
Jerseydave's Avatar
TT Hero
Measure the distance from the ground to the front eye bolt of front spring.
Now measure from ground to rear eye bolt of rear spring.
Make those measurements the same by adjusting the tongue jack.....your trailer should be level now. Buy the correct ball mount to maintain this height and your good.
I would bet measuring ground-to-frame rail front and back will net the same result.
I was njskier on here.
Old 05-07-2012, 08:32 PM
tph's Avatar
tph tph is offline
This helps too:
Old 05-07-2012, 09:24 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
This is what I did. It's somewhere around 18".
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 05-08-2012, 09:56 AM
MC Platinum
Mastercraft owners manual used to give a ball height spec. Not sure if that is the case now.
- Peter
TIRE & WHEEL SALES
