Blown/burnt Channel amp on my JL 6450 ?!
Hey guys !
I need some advices from you stereo gurus... I've been boating all day long today and everything was fine until i noticed at the end of the day that the left front speaker wasn't working anymore on my '08 X2 (no sound or some crackling/popping noises)...I checked the speakers and wires it's working if i switch with the front right speaker so speaker is OK...I then tried to switch some RCA cables and it appears that the channel 1 (which is powering that left front speaker) on my JL 6-450 isn't working properly no matter what RCA cable i plug in... Another strange thing, I tried to play with the Input Sens. and when i touched the knob with a screwdriver it triggered a lound popping noise from the speaker, same if i switch from HP to Off, the speaker is going mad !! What do guys think ? Any possibility of repair ? Brand new amp ? ($$$) |
An input pot costs a couple of dollars. An output transistor costs under $10. The flat rate for parts plus labor to fix most amplifiers, if there is no water damage, is around $100. An equal replacement, same honest power and quality, will cost three times that at minimum. So the cost points in one direction. Repair it. It's a matter of; can you tolerate several weeks at this time of year.
First, try spraying some tuner wash in that pot. David Earmark Marine
www.earmarkmarine.com |
You didn't use Monster Cables, did you? They have a tendency to be too tight and if the plugs are removed frequently, the jacks can be damaged. It wouldn't be the first time a Monster Cable caused this kind of damage. |
Yep first time I touched the input sens. knob the music was back again with some distortion or really LOUD for a few seconds, then no sound or just some some popping sounds etc...
The amp and cockpit speakers are pure stock from factory, wires and RCA look fine, no water damage either ! |
Got some fresh news...Channel 1 still not working but I tried to plug the front left and right speaker in bridged mode on CH 1(+)& 2(-) and now it works fine...That way it seems i have no powerloss, right ?
How come it's working ? I really don't get how amps work sometimes... ![]() |
Same thing is going on with mine. My amp has a broken switch on it. I can usually get it going again by tapping on it. It's annoying.
iPhone Tapatalk
2006 X30 |
Hey Guys, I've got a M6450 that is looking for a new home. It came out of my 2006 X15. If your interested let me know.
