Old 05-31-2012, 11:27 AM
Nick911's Avatar
Nick911 Nick911 is offline
Originally Posted by AZX45OD View Post
2012 X45 6.0 ILMOR. I have not experienced the squeaking, but I did get the MIL engine light once when we were moving at low RPM's for a while pulling my 6 yo on a kneeboard. It then reset and turned off when we restarted the boat. The manual implied that it is related to an emissions sensor. The first time I took it out we actually threw a bunch of engine codes due to some faulty sensors, so the motor went into safety mode. We had to limp back to the dock and have the dealer fix it. For a minute I was afraid that was happening all over again. It also showed me an "F" on the gauge. Any idea what that means?
I can't get my rider profiles to load on the BIG and the dealer said they can't do anything until MC gets it figured out. VERY FRUSTRATING ON A NEW 100K + BOAT!! Not to mention very embarrassing when my Tige and Malibu owning friends are laughing at me for spending that kind of money on a new boat.
The "F" stands for forward I believe. I know because the "F" changes to "R" when in reverse.
Old 05-31-2012, 03:53 PM
X25 ED's Avatar
X25 ED X25 ED is offline
Boat: mastercaft X2, 2009, MCX 350, Moomba LSV 2007 (sold), Maxum 1800 sx 2003 (sold)
yes you are right with that
2012 X25 , 2009X2, 2007 Moomba, 2003Maxum
Old 05-31-2012, 11:49 PM
AZX46OD's Avatar
AZX46OD AZX46OD is offline
Boat: 2014 X46 6.2L
Thank you for the insight on the "F". I will watch that more closely next time. I thought it came on randomly when driving one time...we'll see. I will say that the X45 is an amazing boat for our family and friends. We'll get it all worked out...
Old 06-01-2012, 12:01 PM
gchapman-tt's Avatar
gchapman-tt gchapman-tt is offline
Boat: 35yrs Tournament Team
Originally Posted by Lucky26 View Post
I heard the same squealing noise over the Memorial weekend, the first real time we had spent in the 6.0 X-35. I did not trace it down but it sounds alot like a belt slipping. When did you take delivery of your boat? I took delivery in the latter part of april and the dealer had already installed the upgrade or patch, if you will.
I had the belt squealing issue on my 2012 6.0L 197 back in Sept./Oct. Ilmor had a fix for it, seems that some of the pulleys were not balanced..causing this. Ilmor replaced the tensioner and pulley...never a squeak after that.
Old 06-01-2012, 12:34 PM
Nick911's Avatar
6.5 hours now with 2012 MV8 6.0 no engine squeaks to report.
Old 06-14-2012, 01:32 PM
Jibber's Avatar
Jibber Jibber is offline
Boat: Mastercraft X2 2012 Ilmor 6.0
Mine has now 20 houres on it (2012 MV8 6.0) and i have exact the same squeaking in lower rpms since the beginning i own my baby. Itīs only between 1.000 and 1.300 rpms. Has anyone of you fixed it? Or should i ignore this?
Old 06-15-2012, 07:09 AM
Do not ignore it. I thought that mine was only squeaking at low rpm but found that the engine noise was covering up the squeak at higher rpm. You could possibly have the pulley problem that I mentioned previously. First of all, check the tightness of alternator bolts as the unbalanced wheel will loosen these up.
Old 06-15-2012, 07:52 AM
Jibber's Avatar
Thanks for the reply! I will check it.
Old 06-27-2012, 01:02 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; 2012 X-45 ZFT4, ILMOR 6.0L. CURRENT 2010 X14V, ZFT3, RTP-1
I have the 6.0L too and mine squeaks. Is this just the 6's or does anyone else have the same squeaking? Is this the belt or a pulley that needs to be replaced or just an adjustment?
Sent from my iPhone 4S using Tapatalk 2
Old 06-27-2012, 01:55 PM
Jibber's Avatar
Iīve tested it. In no load running there is no squeaking. But if i put the gear in, there are this squeaking. It sounds like coming from the transmission.
