Old 08-21-2005, 04:35 PM
dchatagnon dchatagnon is offline
Boat: 1993 PS190 285HP Ford 351, Holley 4160
Send a message via AIM to dchatagnon Send a message via MSN to dchatagnon
Rear floor PS190 93
I'm looking to replace my rear floor panel on my boat.
Is it still available through MC? it's pretty hard to find this part specially with the honeycomb stuff...
Any help will be apreciated!
thks.
Old 08-21-2005, 07:33 PM
G-man's Avatar
G-man G-man is offline
A few here have replaced the honeycomp crap with plywood with a coat of resin over it.
06 AWSA Approved Towboat
Old 08-21-2005, 08:06 PM
MarkP's Avatar
MarkP MarkP is offline
thks.
What did you do to your old one??
The wife calls me abrasive
Old 08-22-2005, 09:49 AM
G-man's Avatar
Mark
here's my guess, the bolts that hold the engine cover hinge pulled through. I have seen that on about 6 boats. If larger washers were used it would help. You also have stainless bolts and nuts resting against the alumium and you get a lot of corrosion.
Old 08-22-2005, 10:02 AM
MarkP's Avatar
Well that would blow. I never really looked at mine even though I had it up to put the depth finder in earlier this season..
Old 08-22-2005, 10:07 AM
Hoosier Bob's Avatar
Hoosier Bob Hoosier Bob is offline
Boat: 1993 MASTERCRAFT PROSTAR 190 285HP 351 INDMAR
My corners did the same thing. I carefully peeled the corners (carpet)back and filled the honeycomb with marine grade epoxy. the corners are perfect and square. After the corners are filled and shaped, re-drill and re-glue the carpet. Much stronger and you'll never know it was repaired. This repair should last longer and be much cheaper than marine grade ply.
PS. I went through two tubes on each corner making sure to fill all of the edges about 5" in either direction. Pack it in the cells and it becomes extremely strong. Use a putty knife to shave the carpet off of the alloy.
Old 08-22-2005, 10:26 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I had the bolt pulling through problem with mine. I put a thin strip of plywood across the bottom where the bolts are secured to spread the load and it fixed things right up.
Hoosier Bob sounds like he has a good solution short of replacing it altogether. If I were going to replace it, I'd go George's route. Plywood. Marine epoxy coat. Carpet. Sure, it might rot, but it's cheap and easy to replace (and strong).
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 08-22-2005, 11:43 AM
Boat: 95 PS 190 EFI
Originally Posted by george
Mark
I have that problem on a trailer (alum fenders with ss bolts/nuts). Just go buy some nylon washers to seperate the 2 & you won't have any real problems.
If one day you're asked:
Will you say:
It's time to SKI.
Old 08-22-2005, 03:30 PM
I think I will go with plywood and resin over it. sounds to be the best solution.
Thanks for all your help.
Damien
Old 08-22-2005, 07:33 PM
James O'Keefe James O'Keefe is offline
While we're on the subject, where the rear floor screws to the deck, mine screws were placed in too far and just missed the fiberglass. The were close enough that the outside of the screws grabbed the edge of the fiberglass, so it still holds it in place though(does that make sense??)
Any one else have this problem?
