Old 05-26-2012, 08:16 PM
TonyB's Avatar
TonyB TonyB is offline
Boat: 1991 Prostar 190 Powerslot
Question 91 ProStar: Engine Over Revving in Neutral
After a great day on the boat with friends I headed back to the launch to call it a day. When I approached the launch and reduced the throttle it would not come back to normal. In neutral it was over 2200 rpm. I backed the idle screw all the way out and that reduced the rpms to around 1500. I've looked at everything on my Holley 4160; I've checked and lubed the throttle linkage and every other moving part on the exterior of the carb. Still, it over revs.
Suggestions?
Devil made me do it the first time.
Second time, I did it on my own.
Old 05-26-2012, 08:26 PM
1redTA's Avatar
1redTA 1redTA is online now
choke out of whack?
1981 MasterCraft
19' Skier 351W PowerSlot
Old 05-26-2012, 08:29 PM
John 14:6
Old 05-26-2012, 08:32 PM
Jerseydave's Avatar
TT Hero
After checking to make sure your throttle plates close all the way, start looking for a vacuum leak. Check all vacuum hoses including your PCV hose (if you have one)
You can also spray 2+2 around the intake gasket if you find no other vacuum leaks. If there is a vac leak the idle will increase when you spray near the leak.
I was njskier on here.
Old 05-26-2012, 08:39 PM
John 14:6
Old 05-26-2012, 08:49 PM
TonyB's Avatar
I've had vacuum leaks. They are only an issue at low idle rpms (i.e. rough idle). Once the rpms get above a certain level the amount of fuel overcomes any "vacuum" that may exist.
Ive Checked the springs, the plates, etc. Everything is going through its full range of motion. But the rpms remain unbearably high.
Boat had been running great all day. On the way home I did come out of the hole somewhat hot and then proceeded to the launch at around 35mph till stop.
Anything else?
Old 05-26-2012, 08:57 PM
John 14:6
Old 05-29-2012, 09:24 AM
TonyB's Avatar
Inexplicably, all is back to normal.
Carry on.
