  #31
Old 07-16-2012, 04:03 PM
sschnell sschnell is offline
Boat: 1994 Prostar 205
Greg,
I have a 1994 Prostar 205 that needs a new electrical panel. If I send you the template would you be willing to make up a new one? The black is perfect and would look like new.
Thanks!!
Old 07-16-2012, 04:04 PM
gweaver gweaver is offline
Scott, you have a PM.
Greg
Old 07-24-2012, 04:10 PM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
Greg, I have the same panels you do for my 89 Tristar without the depth gauge in the left panel. Can you PM me a quote? thanks.
Old 08-02-2012, 11:02 AM
TLR67's Avatar
TLR67 TLR67 is offline
Boat: 1990 190
I am in need of one just like this as well... Mine is a 1990.... Key side only.... I will PM you as well....
Old 08-04-2012, 10:58 PM
tockit's Avatar
tockit tockit is offline
Boat: 1989 190 Tristar
Originally Posted by gweaver View Post
OK- dash panels are done. The HemiHead font looks really good- props to whoever found that font and shared it. I know on my hull the word MasterCraft uses a combination of upper and lowercase letters, but I think all uppercase (but with different font size) looks better.
They'll be installed tomorrow, pictures to follow. :crossesfingers Hope I got all my measurements right. Realized that while I measured the hole diameter for the hour meter and depth gauge, I didn't measure the diameter of the trim ring. I left enough space for a 1/4" trim ring on each gauge, so I should be OK.
G
Greg,
I'd like to get a set of panels exactly like the ones pictured, except instead of the hole above the ignition key being used for the hour meter, I want to put my depth finder there.
My depth finder is the same size as the tachometer hole on an '89 Prostar.
I'm assuming you know the diameter, but I can measure it if you need me too.
I'll send you a PM with my address and get you to give me a quote.
Thanks!
PS - Your panels look incredible!
Andy
Old 08-05-2012, 02:03 AM
Andy- PM sent.
Old 08-05-2012, 07:23 AM
zsqure's Avatar
zsqure zsqure is offline
Boat: MasterCraft X-14, '09 Blue
Originally Posted by maristardd View Post
Here a scan of my ignition panel for 94 Maristar 225. No engraving, just something to be cut. Will SolidWorks let you pull this image in, size to correct scale against ruler, then let you draw against it? Or what is easiest for you for me to give you on dimensions? I did not see that I could send image via PM, so am posting.
Yes, bring it into your sketch as a jpg i believe. We do it quite often.
Old 08-05-2012, 02:54 PM
zsqure- I'll have to try that. I haven't had a chance to play with Solidworks in a while (been on vacation) but when I'm back in my classroom Tuesday, I'll give it a whirl.
Thanks for the suggestion/idea.
Greg
Old 10-17-2012, 05:16 PM
dpcsar dpcsar is offline
Boat: Mastercraft Prostar 190 1989
Here are pictures of my panels that were done.
Thank for the work! Looks much better.
Old 10-26-2012, 08:17 PM
Glad you're happy. Your dash looks pretty sweet!! Thanks for the positive feedback!
G
