How to Adjust timing
Quick question, on a 81 Ford 351 PCM, which way do I turn the distributor to advance the timing?
Clockwise.....
James 1989 MasterCraft TriStar 190 SE |
Thanks, one other question if it is firing before the pointer on the timing cover, I need to advance the timing correct?
You tube, search, setting timing 351w
Low idle speed as possible. If it has electronic mod, timing won't change. If it has points - they need a spot of lubed on the rubbing block to cam. Point need to be set before timing is changed. While at it, lube the advance weights under rotor. A good water proof lube like LPS3 on weight pivots. Good Luck.. |
