Old 05-23-2012, 10:18 PM
Originally Posted by André View Post
Interresting.I was thinking something similar tonite if it turns out to be the ECM.(Yes,i'm a hacker and cheap!)Any ideas how he did that? Just jumped the wires together at the injectors?
Thanks for the help and ideas guys!
The ECM only has one set of output leads for each injector, so I don't know how the dealer did this. These harnesses are made specifically for the application and don't have a second set of injector outputs.
Old 05-23-2012, 10:20 PM
Double D's Avatar
Double D Double D is online now
Sorry to say, I am not sure how they did it.
1994 MasterCraft ProStar 205
275 HP 350 Chevy Indmar
Monster Tower & PerfectPass
Old 05-23-2012, 10:33 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Does it only do this when you try to accelerate hard, or can you increase throttle slowly and get it to rev higher?
Unplug the TPS and see if this changes. It will be sluggish and you may see a code/trouble light but go ahead and rev it. If it seems to be OK, check the TPS with a multi-meter set for continuity. If you see the meter react suddenly as you move the throttle, it would seem that the TPS has a problem.
Both.
Will try this tomorrow morning.Would a faulty TPS stop only one injector completely dry?
Thanks for the help guys!
Keep skiing!!!
Old 05-23-2012, 11:22 PM
Both.
I was thinking in terms of acceleration enrichment/deceleration enleanment as a TPS problem. Whether it makes one injector shut off is determined by the actual problem.
I think I would start the engine and wiggle the main harness on the engine, especially near the coolant temperature sensor.
Old 05-24-2012, 08:22 AM
André's Avatar
Will try the famous wiggle the wires trick too!
Thanks Jim!
Keep skiing!!!
Old 05-24-2012, 10:02 AM
André's Avatar
Is there anything between the ECM driver signal and the injectors?
Wires turned out fine between the J2 connector and the injector connector.
Also measured the resistance of the TP sensor,3k to 8k ohms,very linear.
Very windy here,don't know if i'll be able to do some on water testing...
Keep skiing!!!
Old 05-28-2012, 04:23 PM
André's Avatar
Update.
Recheck all the wiring,measured resistance of the wires while whiggling the wires and connectors,didn't find nothing wrong so i went skiing with all my tools in the boat.
We did 20 passes plus a couple more start because of fallen skiers and the engine didn't skip a beat,just like it ran for the last 900 hrs of use.
The wiring diagram show a ground wire for the injectors on my TBI.
Anyone knows where it is cause there's only 2 wires going to the injectors itself...
Thanks for your time!
André
Keep skiing!!!
Old 06-05-2012, 04:55 PM
André's Avatar
7-8 sets of skiing and all is good.Don't know why but the boat is running like it always did,perfectly!Knock on wood...
Thanks to everyone for the help and specially James who took time to talk to me on the phone about troobleshoothing my problem!
Have a great summer!
André
Keep skiing!!!
Old 02-28-2014, 11:09 AM
PineLakeRumble's Avatar
PineLakeRumble PineLakeRumble is offline
Boat: 1994 Prostar 190
Greetings Andre,
I will be looking at a 94MC with the 350TBI not far from you. How have you found this engine as far as strength and reliability over the years? The engine has approx. 800hrs on it and seems to be well looked after. Anything I should be aware of? If I decide to purchase, this will be my first experience with fuel injection in a boat. Any tips/suggestions for a prospective buyer?
Cheers.
Old 02-28-2014, 11:25 AM
For those who like pictures...
